Mercedes W12
Post Reply
jjn9128
769
Re: Mercedes W12
dans79 wrote:
03 Sep 2021, 21:08
atanatizante wrote:
03 Sep 2021, 19:08
Is this lower wishbone fairing a new update for this race?
It can't be new per the technical regulations.
see page 127
https://www.fia.com/sites/default/files ... -06-28.pdf
  • Component - Front Suspension Members
  • Freeze Date - R1-2021
  • Included Components - Wishbones / Links, Track-rod, Push/pull Rod, Bearings, Inboard Brackets not integrated in the survival cell, Fasteners, Wheel Tethers, local electrical and electronic components
Wishbone fairings are covers over the wishbone/tether/brake cable. Which is free to change.
#aerogandalf
Stu
Re: Mercedes W12
This is a great picture!!
Totally different approaches to rear wing and DRS.
zibby43
613
Re: Mercedes W12
Stu wrote:
04 Sep 2021, 10:28
I agree. I really like seeing the direct comparison photos. 8)
zibby43
613
Re: Mercedes W12
And speaking of comparison photos, here is how Merc’s Monza RW stacks up. Looks pretty small!
e30ernest
27
Re: Mercedes W12
From Scarbs:
zibby43
613
Re: Mercedes W12
Another race and another opportunity to see how the W12 rear wing stacks up to its rivals.
W12 RW watch, Sochi edition:
Again, looks pretty slim.
Stu
Re: Mercedes W12
zibby43 wrote:
23 Sep 2021, 20:14
https://twitter.com/albertfabrega/statu ... 40774?s=21
Difficult to say, they seem to have a different methodology to most teams (and definitely to RB) except for AM. There appears to be a fairly significant gap at the leading edge of the second element (the main element looks fairly portly), almost as though they are trying to tune the interaction between two separate elements (as opposed to using a twin element wing as a single, powerful, entity); no doubt this is all to do with both balance and tuning the DRS for maximum effect (a bigger ‘static’ slot gap will allow a bigger ‘activated’ slot gap. The portly lower (‘main’) will still generate a decent amount of downforce with the DRS open.
Since the teams have moved to two very similar sized elements (rather than the classic main and secondary elements), the behaviour is NOT exactly as with the classic structure.
Zynerji
111
Re: Mercedes W12
Stu wrote:
04 Sep 2021, 10:28
This shows an obvious difference that would be neat to quantify. The RBR wing DRS /gooseneck seems to have like 0 contact to the top wing surface (not the more important surface, I agree) where the Merc loses like 5% of the surface to these mounts. How much does that small difference really make?
zibby43
613
Re: Mercedes W12
Stu wrote:
23 Sep 2021, 21:35
zibby43 wrote:
23 Sep 2021, 20:14
Yeah, although the photos aren’t all taken from similar angles, distances, etc., I was mainly focusing on the chord width (top to bottom) on the upper element, which seems smaller relative to the RB.
That same element also tapers on the uppermost edge near the end plates, further reducing the amount of surface area.
pursue_one's
97
Re: Mercedes W12
El Scorchio
Re: Mercedes W12
Seems to be a trend. Hamilton seems to be able to handle less rear wing than Bottas consistently. Have they usually had slightly different front wins too? It's not something I've noticed.
west52keep64
51
Re: Mercedes W12
Re: Mercedes W12
Bottas's is a quali setup, Hamilton's a race set up. Hamilton's allows slightly more top speed so better for defending on the long straight.
zibby43
613
Re: Mercedes W12
Mercedes have a new front wing.
Tvetovnato
Re: Mercedes W12
zibby43 wrote:
26 Sep 2021, 07:29
https://twitter.com/LuisFeF1/status/144 ... 79564?s=20
They both went for the old front wing during Q though. Perhaps this is a test for the coming tracks..
Edit: which I now with my limited Spanish knowledge realize that the guy also wrote above, hehe.
Post Reply
