A.J.O wrote: ↑Sat May 21, 2022 7:31 pm
SmallSoldier wrote: ↑Sat May 21, 2022 6:47 pm
A couple of interesting comments from Key:
A) The correlation of the parts brought to Spain was as expected.
B) The car was setup with a Race bias instead of a Qualifying bias.
With the degradation that some teams experienced during practice it might be the smart call, the question is how much progress Daniel and Lando can make with the strategy.
For point B, do you know how the set up Hierarchy works with this team?
Are both garages given a base line to start then go in there own directions from there?
Do both work together?
How much input and how good are either or both drivers on the set up aspect of driving.
I can’t seem to find any decent information on this subject.
I spent 10years setting up super late model oval cars. my data was so primitive compared to what these cars produce I am completely intrigued with how it works at this level.
I could only speculate really, but from previous seasons comments, they will always start the sessions with the baselines driven by the simulations done before the race, depending on the program the drivers may try different things and go in different directions, but it will depend a lot on what the team is trying to achieve on a particular session, what test items they have planned and whether is a data collection run or performance oriented run.
The debrief is done with both drivers simultaneously, therefore there is data sharing between them and they have access to what the other side of the garage is doing… There is constant feedback for both of them in regards to what the other car is doing, so they are working together. At some point though, the setup will be the one that the driver feels the most comfortable with (we have seeing in previous races that Lando and Daniel have run different wing levels with for example gurney flaps on one car and not on the other.
Only the Team will know how good is the driver’s feedback, but Daniel has a lot of of experience in a couple of different teams and that has to be valuable during debriefing, Lando is often getting the most out of the car, so I’m guessing his feedback is also good for him to achieve the level of performance he has.
We usually see a lot of improvement from Friday to Saturday, an important part of it comes from of course going with higher engine modes, but there is a constant feedback loop back to the factory, where first they will correlate the baseline to the simulator, once they are comfortable with that, several different setup directions will be tried in the simulator during Friday night and those will be applied to the car for FP3, at which point if the setup changes are positive, they may fine tune a bit more before Qualifying.
