That makes a lot of sense. I like the punishment.AeroDynamic wrote: ↑Fri Sep 30, 2022 10:02 amFIA should fine any team guilty of breaking the cap, by giving them a sizeable fine out of their next budget.
But, if they won the world title.. im not sure it is enough. Certainly if it is above the 'minor' limit of 5%, reportedly.organic wrote: ↑Fri Sep 30, 2022 10:03 amThat makes a lot of sense. I like the punishment.AeroDynamic wrote: ↑Fri Sep 30, 2022 10:02 amFIA should fine any team guilty of breaking the cap, by giving them a sizeable fine out of their next budget.
There's no consequence.AeroDynamic wrote: ↑Fri Sep 30, 2022 10:02 amFIA should fine any team guilty of breaking the cap, by giving them a sizeable fine out of their next budget.
Perhaps the amount should reflect where they finished in the championship to some extent.
Another element could be that they have to absolutely stay within the cap the following 2 seasons with no 5% exemption above the limit afforded to them.
Make them give a similar amount to the bottom 3 teams, even it outAeroDynamic wrote: ↑Fri Sep 30, 2022 10:08 amBut, if they won the world title.. im not sure it is enough. Certainly if it is above the 'minor' limit of 5%, reportedly.organic wrote: ↑Fri Sep 30, 2022 10:03 amThat makes a lot of sense. I like the punishment.AeroDynamic wrote: ↑Fri Sep 30, 2022 10:02 amFIA should fine any team guilty of breaking the cap, by giving them a sizeable fine out of their next budget.
Given that one team is quoted to be "significantly over", and another to be down to just an "administrative error". There is no way it could be down to just "Being too complex" or "Different Views"JordanMugen wrote: ↑Fri Sep 30, 2022 12:24 pmMaybe the trouble is different views of accounting and costings?![]()
Definitely not. If overspending gives you a title deciding advantage in a close season, a points deduction is the only penalty that can or should be given since it’s a direct unfair sporting advantage.101FlyingDutchman wrote: ↑Fri Sep 30, 2022 11:02 amWhatever you overspend gets taken off next years budget limit for that team. Seems a pretty simple rule.
