Post Reply
Maritimer
19
Anyone else see the gentleman in a Porsche jacket talking to Jos during Q3 in the garage?
Ryar wrote:
02 Jul 2022, 19:01
02 Jul 2022, 18:41
ispano6 wrote:
02 Jul 2022, 18:29
Wow that worked out well for Liam, didn't it.
It sure did. I am sorry for Juri. I think the punishment was way too harsh.
I am a person of color and have faced discrimination, but I do think it was harsh. All that he grew up dreaming of, seems to have gone with a naive mistake. Racism and all kinds of discriminations should be absolutely unacceptable in the society. The problem is, a lot of kids like Yuri have grown up in a atmosphere where using "n" word casually was normal and it became part of vocabulary for them, which brought his downfall. I have seen my own people using "n" word casually! Not sure how many such talented kids are around who would go down that path unconsciously. The world should strive to improve on racism where it is NOT being monitored, more than where it is and parents/guardians/schools should provide an upbringing that also educates the evils of racism. That would bring true change.
I totaly agree to that!
zibby43
613
Huh. Wonder what the FIA will do.
From AMuS:
“ Does the floor trick exist?
Many are wondering whether the initiative was really just the result of the new FIA President's activism to show that the association is in control. Or if there is more behind it. Does the FIA ​​want to compress the field by tightening the underbody rule? The blatant superiority of Red Bull and Ferrari does not fit into the objectives that Formula 1 has set itself with the new cars.
During their examinations of the planks and underbody, the scrutineers have apparently discovered that some teams are deliberately playing with the rigidity of the huge base plate. When the FIA ​​threatened at the last meeting of the technical directors that the central part of the floor should be uniformly stiff in the future, Red Bull and Ferrari went on the barricades.
The competition suspects that the floor of both cars deforms in certain places, thereby increasing the tunnel effect under the car. There should be enough air between the chassis and the base plate for the floor to move. That could generate significantly more downforce and would explain why the two cars, which are so different on the outside, are so much better than the rest.”
Now we know why RBR and Ferrari were so irritated by the proposed porpoising test that looked more closely at the legality planks.
chrisc90
36
Surely plank wear has been monitored since forever?
zibby43 wrote:
02 Jul 2022, 21:30
From AMuS:
You're a little late with your message @Zibby. RBR has already used their new floor this weekend.
Can you guess three times what that floor looks like and which rules it complies with. :)
zibby43
613
There is no official rule yet.
zibby43 wrote:
02 Jul 2022, 21:45
The floor has been made as rigid as possible. Too bad I have to ruin your party. :wink:
zibby43
613
02 Jul 2022, 21:52
zibby43 wrote:
02 Jul 2022, 21:45
What party? It’s more about the planks than the floor. Article just came out today.
If this design is “allowed” by the spirit of the regs, it should continue to be allowed. If it’s not, it shouldn’t. I’ve always been consistent about that. No matter the team.
zibby43 wrote:
02 Jul 2022, 22:08
02 Jul 2022, 21:52
zibby43 wrote:
02 Jul 2022, 21:45
It is all about the floors.
zibby43
613
02 Jul 2022, 22:23
zibby43 wrote:
02 Jul 2022, 22:08
02 Jul 2022, 21:52
That’s not my understanding of the article.
siskue2005
70
zibby43 wrote:
02 Jul 2022, 21:30
From AMuS:
Yup I was puzzled by that aswell, I have posted about it before as to why Horner and Ferrari are against the new TD when their fans were celebrating here :lol:
the FIA has published the rules which comes into effect from France onwards about the plank....so there is no smoke without fire.
The FIA notes that any car configured around a plank which flexes by more than the 2mm regulation limit will be considered in contravention of regulations 3.5.9e and 3.15.8a. Those regs state:
“3.5.9e. The thickness of the plank assembly measured normal to the lower surface must be 10mm ± 0.2mm and must be uniform when new. A minimum thickness of 9mm will be accepted due to wear, and conformity to this provision will be checked at the peripheries of the designated holes.
“3.15.8a. Bodywork within RV-PLANK may deflect no more than 2mm at the two holes in the plank at XF=1080 and no more than 2mm at the rearmost hole, when the car, without driver, is supported at these positions. The car will be supported on 70mm diameter pads, centred on the holes, and only in contact with the underside of the plank assembly. The displacement will be measured at the supports, relative to the reference plane at the centre of each hole.”
https://the-race.com/formula-1/how-f1s- ... ed-detail/
LM10
120
siskue2005 wrote:
02 Jul 2022, 23:08
zibby43 wrote:
02 Jul 2022, 21:30
From AMuS:
Has this rule been existing since the beginning of the season or it's just now the FIA is changing it in order to to have a more level playing field?
zibby43
613
LM10 wrote:
03 Jul 2022, 00:44
siskue2005 wrote:
02 Jul 2022, 23:08
zibby43 wrote:
02 Jul 2022, 21:30
From AMuS:
But the regulations did not include the specific wording of that original guidance. As a result, some teams have conceived layouts around the regulation wording rather than the understanding outlined in the meetings.
What has this allowed them to do? The 2mm flexibility tolerance is defined at the leading edge of the plank. But at the rear – around where the driver sits – they have engineered the mounting of the plank and skid block in a way which gives a degree of cushioning. From France this interpretation will not be accepted.
Any cars with this solution in place will be required to make changes in order not to be considered in breach of those two regulations.
Could have big ramifications for RBR and SF.
ispano6
143
Uniform doesn't mean it has to be perfectly flat. I doubt the FIA would be able to accurately measure or find fault in their designs. RB/SF will always be more clever and out maneuver them and Mercedes. They will be playing catch up and Mercedes will keep politicking off the track and just look like poor sports for having been so off the mark. **mod edit**
wogx
Post Reply
