Red Bull RB18
Re: Red Bull RB18
https://www.skysports.com/watch/video/s ... apore?s=09
Max says in the interview that there is no new chassis at Singapore. Jokingly or not, he says he made a deal with the team that he will keep the old chassis for singapore if he wins in Monza. No mention if it will come at a later date
Re: Red Bull RB18
Vertical flap for Singapore
gandharva
226
Re: Red Bull RB18
Thu Sep 29, 2022 8:14 am
https://i.imgur.com/pMtAD4F.jpeg
Some reflective material applied to the brake drum of the RB18 this weekend. Not surprising that some modifications are made in this area since it's so demanding on brakes
Looks more like a taped on sensor to me. You can even see the cables.
Re: Red Bull RB18
Rb18 ready for pitstop practice. Floor detail looks same as Monza so far
CMSMJ1
CMSMJ1
Re: Red Bull RB18
Moved a load of non RB18 posts out from this thread into an Active suspension one - go ahead, fill your boots in there..
RB18 please in here
IMPERATOR REX ANGLORUM
Re: Red Bull RB18
Singapore GP update
Re: Red Bull RB18
Sounds like they are trying to thicken the aero map.
Re: Red Bull RB18
Checo no longer running the floor with cutout. Can't tell by eye without comparison whether these fences are the modified fences mentioned in the tech scrutineering docs. Might just be on Max's car
Re: Red Bull RB18
Side-by-side of new and old floor fences. Despite different angles, it can be seen that fences 3 & 4 haven't changed, and I don't think 1 has either. Fence 2 is quite a lot different, intersecting with the leading edge of the floor further outboard, and with a slightly reworked profile (less S-shaped)
BlueCheetah66
BlueCheetah66
Re: Red Bull RB18
Thu Sep 29, 2022 3:03 pm
Am I the only one that thinks the undercut of the sidepod looks a bit larger in this photo. It may have been an upgrade from previously in the season but I hadn't noticed it before
johnny comelately
johnny comelately
79
Re: Red Bull RB18
What is the 2 piece apparatus being fitted around the nose of the Perez car?
Re: Red Bull RB18
BlueCheetah66 wrote:
Fri Sep 30, 2022 5:20 pm
Sidepod/floor intersection hasn't changed since Baku
Re: Red Bull RB18
Completely opposite packaging between MCL/RB, even though both have a compressor at the back of the tub, & use air air intercoolers. MCL puts the coolers so far forward* & away, with no undercuts on their tub, while RB did everything to put them right at the compressor, and dug large indurcuts in the sides for this purpose, & created those exotic floating mounting points (number 3 & 4) to make even more room (for the opposite compressor duct, I guess, & other things)
https://twitter.com/NicolasF1i
Re: Red Bull RB18
Shorter pipe work between the turbo and the intake manifold is superior (slightly less energy wasted to maintain charge in the ductwork volume since air is compressible). I'm surprised that Red Bull have not switched to the design we have now seen from Ferrari/Mercedes/Renault.
ispano6
143
Re: Red Bull RB18
Tue Oct 04, 2022 3:20 pm
Probably not until they use their own bespoke RBPT layout. The Honda PU layout has reasons and limitations, low CoG being one of the key factors.
