McLaren MCL36
zxof
zxof
Re: McLaren MCL36
SmallSoldier wrote:
Mon Mar 28, 2022 6:30 am
I know there is a lot of questions in regards to the choice of sidepod concept from McLaren, but from this view I really like how it looks… Hope they get the concept to work
https://i.imgur.com/61U5Ybd.jpg
Vía XPB NextGen-Auto
Two of the faster teams have a considerable size sidepods so it's not all about "slimming them down".
SmallSoldier
SmallSoldier
479
Re: McLaren MCL36
zxof wrote:
Wed Mar 30, 2022 2:02 pm
Not disagreeing, clearly the wide sidepod concept has shown more benefits this season and going for the slimmest package is not showing the same amount of performance.
I would argue that a lot of focus is placed on the sidepods, but the downforce generated from the floor might be more critical… Since the teams with slimmer sidepods (McLaren, Mercedes) aren’t create as much DF from the floor, they are been forced to run more front and rear wing, therefore more drag and the penalties that come with it… While still missing DF compared to the likes of Ferrari and RBR.
zxof
zxof
Re: McLaren MCL36
SmallSoldier wrote:
Wed Mar 30, 2022 3:07 pm
Yep, I get your point.
Ericd735i
Ericd735i
Re: McLaren MCL36
Maybe someone smarter than me can answer. Watching onboards the car looks just too stiff and understeery up front in the low speed corners. In a normal car I’d say they need to soften the front spring/anti-roll bars, but I know you have to have some spring rate to counter the downforce. Is there a reason they can’t run softer for more mechanical grip and the heave dampers counteract the compression from the aero?
JordanMugen
85
Re: McLaren MCL36
The sidepod shape dictates the pressure distribution on the top of the floor, and the downforce generated by the floor is of course based on the pressure differential between the top and the bottom of the floor, so I don't think the "downforce generated from the floor" is independent of the sidepod shape.
JordanMugen
85
Re: McLaren MCL36
What is the advantage of the McLaren splitter design? Why would you want to send that clean, central air flow not underneath the car but rather out to the sides?
scheffers
scheffers
Re: McLaren MCL36
JordanMugen wrote:
Thu Mar 31, 2022 3:53 am
Regulations, these 'splitters' are used to create vortexes on the floor edge...
Re: McLaren MCL36
Nice Close-up...
Pity it doesn't work...
Emag
Emag
84
Re: McLaren MCL36
mclaren111 wrote:
Thu Mar 31, 2022 11:42 am
Nice Close-up...
https://pbs.twimg.com/media/FO3mFn0X0A0 ... ame=medium
It does work. That's not the problem they have though.
BassVirolla
Re: McLaren MCL36
scheffers wrote:
Thu Mar 31, 2022 5:46 am
Not for regulations; other cars are taking the air from the splitter (a.k.a. tea tray) under the floor. The MCL36 takes that air over the floor, from the center to the outside, in front of the sidepods. Probably for outwashing front tire wake.
What are essentially used to shed vortexes along the floor edge are the strakes.
Re: McLaren MCL36
Emag wrote:
Thu Mar 31, 2022 11:50 am
Nice Close-up...
Ok... I thought it was our floor... What is our problem ?
Marc.W
26
Re: McLaren MCL36
mclaren111 wrote:
Thu Mar 31, 2022 12:58 pm
Nice Close-up...
The floor is quite a sizeable area 😂
Emag
Emag
84
Re: McLaren MCL36
According to the team, they are missing downforce, and quite a lot of it.
Obviously, they can have plenty of downforce from the wings so you have to assume they are missing underfloor downforce, and the reason why, I can't tell you because it could be many things. Probably even the team doesn't know 100% why, otherwise they would have a fix ready soon.
But the area you showed, is a detail on the outer edge which helps seal the floor (I think). And it wouldn't make much sense for the thing that is supposed to increase the floor efficiency to be the culprit behind the lack of its efficiency.
Plus, Ferrari brought a very similar design in Bahrain for their car, so we can be certain it's theoretically sound at least.
Re: McLaren MCL36
I think releasing some air from the side, will encourage air flow from the front. It's a manipulated Venturi efdfect.
Re: McLaren MCL36
Emag wrote:
Thu Mar 31, 2022 2:45 pm
Thanks for the info... :D
