McLaren MCL36
Re: McLaren MCL36
1 - The diffusers don't flare out laterally any more.
2 - The duct is extended downwards, not rearwards.
Re: McLaren MCL36
PhillipM wrote:
Tue Apr 12, 2022 7:51 pm
They don't flare out as much as they used to, and what is happening to the air between the wheel winglet and the wall of the diffuser, does it not exist? You completely dodged the question.
What do you think is happening to the air that's passing by that yellow line?
Re: McLaren MCL36
No, they just don't flare out. It was prohibited in the rules.
Re: McLaren MCL36
PhillipM wrote:
Tue Apr 12, 2022 10:57 pm
The ol' don't believe your lying eyes strategy, bold.
Still dodging the question.
Re: McLaren MCL36
That's going upwards, not outwards. Check the straight metal plate at the bottom. Or absolutely any photo from directly behind the car. There's a thread here with dozens of them.
Re: McLaren MCL36
PhillipM wrote:
Tue Apr 12, 2022 11:54 pm
Nuh uh, don't believe your lying eyes.
okie dokie.
Re: McLaren MCL36
Indeed. And I notice that some teams have an inward deflection of the diffuser upper corner just before the rear edge - it's visible on the McLaren image. This presumably allows them to form a bit of lateral outwash in the top corner of the diffuser.
Re: McLaren MCL36
Don't believe your lying eyes :lol: 3 cars 3 different attempts to create outwash with the diffuser within the regulations with flowvis to boot, but yeah. Fake internet points = correct around here I guess.
djos
115
Re: McLaren MCL36
godlameroso wrote:
Wed Apr 13, 2022 12:59 am
https://pbs.twimg.com/media/FMSIv6yXoAg ... ame=medium
You are seeing what you want to see, not what is actually there.
"In downforce we trust"
vorticism
vorticism
337
Re: McLaren MCL36
I think you were saying the diffusers kicked out where the brake duct wing is, but this is not evident in the photos you posted. I see a straight wall on the side, and the only sharp bend is vertically along the topside edge. There's something in the regs forcing this, otherwise we see other types of shapes amongst the teams. Remember previous seasons, where the diffuser side was as curved as the diffuser ceiling? Triple gurney flaps on the vertical edges. That's not present in these photos. Compare to the RB18, it's basically straight sided all the way to the end. If anything it gradually tapers in toward the end, away from the brake ducts.
Re: McLaren MCL36
It's very easy, if the effect was as powerful as you think it is (apparently based on your setup in a computer game, that doesn't model airflow at all and doesn't even model tyres correctly) - every car on the grid would taper the rear brake ducts from very narrow at the front to wide at the back to accelerate the airflow between the side plate and the diffuser.
Not a single one does.
Re: McLaren MCL36
Thus:
1 = Straight & Not Rounded as it looks in Picture ?? Optical Illusion ??
Lucky
Lucky
157
Re: McLaren MCL36
Re: McLaren MCL36
godlameroso wrote:
Tue Apr 12, 2022 10:38 pm
What you are seeing is the radiused corners at the top of the diffuser, but the vertical walls are not flared.
This is a Red Bull but you can imagine the same for Macca.
vorticism
vorticism
337
Re: McLaren MCL36
Any guesses how much that weighs? Two guys, barely straining, holding it by its thin fins. 15 kilos?
