McLaren MCL36
Post Reply
Re: McLaren MCL36
The new splitter...
It has a cooling hole so it probably contains more stuff than before indeed :mrgreen:
AMuS
Old
f1rules
569
Re: McLaren MCL36
mclaren flow in wet
SmallSoldier
473
Re: McLaren MCL36
Wet sessions always provide cool pictures:
Via: Suzuka Circuit
bauc
Contact:
Re: McLaren MCL36
SmallSoldier wrote:
07 Oct 2022, 13:30
https://i.imgur.com/oPyxL47.jpg
Via: Suzuka Circuit
I love how you can see vortices forming behind the front wheel
michl420
19
Re: McLaren MCL36
Is the strut for the floor new for this package in suzuka or was it in singapor also there? Or maybe testing?
One
One
Re: McLaren MCL36
How interesting to see the chassis of the car is clearly visible seen from the front to the back along the long ax of the car, and the water spray on the both side of the car like a wall, making a huge vortices right behind the rear wing.
These air flow starting from the front end of the floor, rise up above the rear tyre like a triangle walls, ... Are these working like a skirt up see down to keep the upper body aero effect nice and clean?
SilverToM
Re: McLaren MCL36
I wonder what the engineers have to say about the rain.
I mean that at the Barcelona test the rain tire test and here the rainy weather reveals the tricks of the car.
Or are they also happy at McLaren to see the reality after the simulations?
SmallSoldier
473
Re: McLaren MCL36
SilverToM wrote:
08 Oct 2022, 21:13
Even though the rain does help visualize a few things, with water been heavier than air, it is not an actual representation of what is happening with the air flow… But it gives a general idea… For the most part, you will see most teams showing very similar patterns.
McLaren sees the reality at the Wind Tunnel and if they need track confirmation, they would use Flo-Viz, no need for a rainy day :)
SmallSoldier
473
Re: McLaren MCL36
Under construction:
Via: n_mode_log
Re: McLaren MCL36
A nice pic of the internal ducting of the cooling air
mwillems
21
Re: McLaren MCL36
Blackout wrote:
17 Oct 2022, 14:43
https://i.imgur.com/Bee5OvU.jpg
They've done about as much as they can for the undercut this year, it's pretty tight down there, it'll be interesting to see how revised the cooling solution is next year and the sidepod shapes they choose to run with. I assume it will be more sculptured with a bigger undercut but who knows.
Give a man a fire, and he will be warm for a night.
Set a man on fire, and he will be warm for the rest of his life.
SmallSoldier
473
Re: McLaren MCL36
An interesting view of the changes to the MCL36 from the launch version:
mwillems
21
Re: McLaren MCL36
SmallSoldier wrote:
27 Oct 2022, 19:39
The sidepod inlets don't change at all in that view, so not the highest level of detail.
SmallSoldier
473
Re: McLaren MCL36
mwillems wrote:
27 Oct 2022, 22:54
SmallSoldier wrote:
27 Oct 2022, 19:39
I think the geometries are pretty spot on for the changes so far… May be lacking some detail, but it is a good reference to understand how much it has changed
Re: McLaren MCL36
SmallSoldier wrote:
28 Oct 2022, 04:38
mwillems wrote:
27 Oct 2022, 22:54
SmallSoldier wrote:
27 Oct 2022, 19:39
I'm not convinced by some of the other comparisons,.namely the RB one where it has the sidepods getting substantially wider through the season, which hasn't happened at all. This is basic geometry that they're failing with
So I can't really trust the accuracy of any of them now, especially with major changes also omitted
Post Reply
