[MVRC] Mantium Virtual Racecar Challenge 2022 (Grand Prix Cars)
yinlad
Re: [MVRC] Mantium Virtual Racecar Challenge 2022 (Grand Prix Cars)
TalnoRacing wrote:
30 Jul 2022, 10:46
Finally got a car together and submitted an entry. Could not get CFD done, so I am hoping I didn't get it too wrong.
https://i.ibb.co/qgVDd9V/TR22.jpg
I heavily considered a 'eggplant' nose, just couldn't bring myself to do it :lol:
MVRC - Panthera
spacehead3
Contact:
yinlad wrote:
30 Jul 2022, 10:16
LVDH wrote:
30 Jul 2022, 08:22
yinlad wrote:
30 Jul 2022, 00:06
Done a bit more testing and I'm very confused now. If I run the wheels and mandatory parts separately, I get all samples in post. Same for my cars files. But once I combine them and do a run, the post processing stuff that generates the VTKs crashes and fails.
Not expecting miracles but if anyone has any idea on things to try I'm all ears. I'm going to try a run with mflow 'd' version as a hail mary in case some config change in 'e' is interfering with openfoam some how but it's a wild stab in the dark
When you load a case which contains all files, do you see everything in MFlow? You might face an issue once mentioned here, that the files might not be in the same scale (some km long, others only mm?).
Yeah everything is there. As I say I've run 2 separate cases (mandatory parts and my parts) that both generate the full VTK suite, but when combined break for some reason.
It outputs the all numbers correctly, but something about visualisation seems to be broken.
My plan is to start with the mandatory files and add my bodywork in piece by piece until it stops generating everything. From there I should hopefully be able to fix it [-o<
Do all of your parts intersect fully with the mandatory parts? ie. No face to face surfaces, very acute angles, etc. that might cause a meshing issue.
Max Taylor
spacehead3
Contact:
TalnoRacing wrote:
30 Jul 2022, 10:46
The ol' Caterham nose. Nice.
Max Taylor
RicME85
52
Contact:
Talno =D> Your modelling skills have come on leaps and bounds since you first joined the challenge
TalnoRacing
RicME85 wrote:
30 Jul 2022, 15:23
Thank you for the compliment.
variante wrote:
30 Jul 2022, 11:53
TalnoRacing wrote:
30 Jul 2022, 10:46
Looking sexy! And that's my favorite sidepod configuration.
But, since you haven't run CFDs, i'm concerned about your:
- Cooling. Your cooling exhaust might be way too small. I had big issues myself with that.
- Balance. That's a very small rear wing compared to the front wing...
- Wheel deflectors effectiveness. They created more harm than good in my simulations (7.5% downforce drop). I think they need a lot of optimization to work (or a lot of luck getting them right the first time).
My cooling is based on the previous generation cars, similar sized inlet, outlet, and radiator size, so I hope that will be enough.
Ft5fTL
Contact:
This is the car im submitting for the first round:
Mantium Challenge - Pure Power Racing
CAEdevice
45
Contact:
Ft5fTL wrote:
30 Jul 2022, 19:15
What a car! The nose seems to be designed to orient the flow and reduce the effects of upwash on cooling.
Ft5fTL
Contact:
Yeah that was my initial intent to cope the horrible upwash i was getting from the front suspension. It helped somewhat but not enough to get rid of that big sidepod with holes.
LVDH
44
RicME85 wrote:
30 Jul 2022, 15:23
Oh, I totally missed out on the fact that it is a Talno design. That explains the creativity. I guess we cannot expect it to look like this for the next race, independent if I change the rules...
Ft5fTL wrote:
30 Jul 2022, 19:15
Yes!!! As always, cool render. Good work!
yinlad
spacehead3 wrote:
30 Jul 2022, 15:02
Kind of related, my RW planes were mirrored down the centre and that was causing it all to break!
MVRC - Panthera
LVDH
44
yinlad wrote:
30 Jul 2022, 23:26
spacehead3 wrote:
30 Jul 2022, 15:02
Good that you figured it out.
I do not quite understand it though. There was a small gap to the symmetry plane and the simulations crashed?
yinlad
LVDH wrote:
31 Jul 2022, 08:05
Nope no gap, but the stl mesh was a bit funky around where it mirrored in the centre. That's all I can imagine it was. But it doesn't make much sense. Especially considering most of the car is made up of mirrored parts
MVRC - Panthera
variante
131
Another sexy car!
The front reminds me of the BMW-Sauber from 2008 (not just for the nostrils :lol: ), which is one of my all-time favorite.
I guess i'll wait for the official images to see better what's going on with the cooling exhaust.
Ft5fTL
Contact:
variante wrote:
31 Jul 2022, 11:43
F1.08 is also one of my all time favorites, just behind Williams BMW Fw25. Its just 2 extra holes on sidepods nothing special :lol:
spacehead3
Contact:
Well, I'm about ready to submit so, here you go:
I imagine by now a lot of you have found this:
https://maxtayloraero.com/2022/01/17/ae ... 22-f1-car/
Unfortunately this new "official" version has lost a good chunk of performance from what I had in that post. Very curious to see how it stacks up against you all!
Max Taylor
Post Reply
