Thanks Yinlad and Koldskaal for sharing these pictures ! That’s very interesting.
Here is my contribution to this cooling discussion, as promised. I’ve tried to keep it simple but it is still a long post (apologies!). To keep the discussion going, please ask more questions about my results and share what you have learnt too.
Cooling chimney – why ?
When I started thinking about entering this competition, I saw :
- Very open rules for the bodywork, with a big regulation box.
- Posts about how difficult it was to hit the cooling target of 3,0, having to deal with a lot of dirty flow at the back of their car.
So I immediately thought that it should be possible to send all these cooling losses above the rear tyre and outside the rear wing (where it can’t hit any useful geometry -
red arrows), and/or even to get some of it to hit the front face of the rear tyre to reduce drag (
red circle). So the idea of a massive pre-2009 cooling chimney became obvious, which would also make my car unique.
These 2022 cars need a wide bodywork anyway, which allows a large radiator and cooling exit to be placed outboard. Then, you can have a downwashing ramp inboard of the chimney to send clean flow to the diffuser top surface, feeding the beamwing and rear tyre contact patch nicely (
blue arrows).
It all sounded (too) perfect ! See picture below :
Does it work ? Sort of…
However, it then became clear that the regulation box was not tall and wide enough for my concept to work, and I should have bailed out at that point. But I didn’t and still drew a large outlet as high and outboard as possible, with a vertical exit tangency. The inboard ramp looked narrow but I hope it would be enough.
Official cooling result for Race 01 was 2,85.
For Race 02 I made the inlet and outlet larger, sacrificing the ramp width. A large vertical plate was added to stop cooling flow from spilling into the ramp. Unfortunately this only gave me 2,93 in Race 02.
See the geometrical evolution below :
The streamlines and the Cp_tot slice below are from my Race 02 car. You can see that some of the cooling flow goes to the desired region above the rear tyre. I was also able to protect the flow on the ramp with that large plate. Unfortunately, it is clear that there is still a large amount of cooling flow coming back inboard and hitting both the rear wing and the beamwing. Which is why it has only « sort of worked ».
Killing the concept – the delta.
Between Race 02 and Race 03, I got rid of the chimney and went to a more conventional cooling exit layout, removing the inboard ramp in the process. It was the only way to reach the cooling target of 3,0 anyway, but I was curious to see how much performance it would cost.
You can see the results on the picture below :
(Bear in mind that the numbers quoted come from my very unrefined setup, with a development floor and rear wing that were worse than the Race 02 spec. Both configurations have around 2,9 cooling.)
Losing the cleaner flow from the ramp is obvious on these pictures (blue circle), which ends up towards the beamwing and around the diffuser, protecting it a bit better from the tyre wake.
However, the conventional configuration improves Cp_tot towards the rear wing. As this is not a particularly efficient part of the car, I thought the trade-off would be much worse, but I was clearly proven wrong.
So why did it not work ?
Apart from the obvious failure of sending all the cooling flow away from my own rear wing, I still thought that the flowfield of the cooling chimney was better. Maybe it didn’t work because :
- I didn’t manage to get enough clean flow into the ramp and towards the beamwing to really exploit this concept ? It would have worked better with a lower cooling requirement, but would it have been enough ?
- My beamwing design is not good enough ?
- The rear suspension creates too much blockage and wake by itself that it doesn’t matter if you send clean flow into this region ?
- Maybe higher suction from the rear wing is much more important to pull on the diffuser than protecting it from ingesting the tyre wake ?
Conclusion :
If sending the cooling losses towards the rear suspension is more beneficial than towards the rear wing, then Tolo’s sidepod design is a very neat answer. It retains a ramp that will send clean flow around the diffuser.
Another way to look at it is to go for Koldskaal smaller chimney (looking very much like a 2008-spec one). If you can size it perfectly so that the flow coming out of it fully goes above the rear tyre and outside the rear wing, then it is free cooling that you don’t have to carry around further inboard.
Maybe the best configuration is a combination of these 2 cars. I will certainly try that before Race 04 !
