Alfa Romeo C43
FW17
168
Re: Alfa Romeo C43
Maybe the Alfa Romeo floor is designed to pull more air from above the floor like in Porsche group c cars while the outwash from front of the floor seals the edge of the throat.
Re: Alfa Romeo C43
09 Feb 2023, 02:27
Look at what Porsche did to the 919 prototype, once they were free of regulations:
Exactly - free of regulations. Mechanical seals are second to none, you turn your flow from 3D to almost 2D and you reduce the "waste" of 3D flow.
With these F1 cars, no skirts are allowed, so you need to maximise what you have. If inwash is allowed, you'll likely pick up some front tyre wake and diffuser performance is out the window. So you "seal" with forced outwash, which is already induced by frontal vanes. With outwash, you can now sculpt the floor edges to benefit from edge-vortex-induced low pressure and generate some downforce. Then we also have the flow changing with varying ride height, so edges are crucial there too.
It's true you are maybe wasting some energy with lateral expansion before diffuser, however - there is also some amount of air sucked into diffuser between rear tyres and diffuser fence. Teams even make a cut to diffuser fence to allow more air to get in. I think this is an area where RB was taking extra care with their downwashing and wide sidepods. With that design, you are also pushing the air into that zone on purpose - air that's not compromised by front tyre wake.
#Aerogimli
Stu
Re: Alfa Romeo C43
FW17 wrote:
09 Feb 2023, 09:31
https://encrypted-tbn0.gstatic.com/imag ... w&usqp=CAU
This is essentially the function of the floor cutouts as seen on the Alpine & RedBull (and others, probably) last year. Except they featured an exit from the front floor, a carefully shaped ‘winglet’ and an inlet to the rear floor. The winglet serving to create/harness the vortex flow from the outlet; the inlet ‘pulling’ airflow from the upper floor surface.
This worked in conjunction with the ‘skate’ floor-edge wing acting as a strake.
You get more work out of the air from the outlet as it is re-energised by the vortex (which both ‘seals’ the floor edge and the inlet, the air going into the inlet is already very energised. This is most likely’boosted’ by careful positioning of the end of the undercut.
It’s very clever!!!
Andi76
Andi76
388
Re: Alfa Romeo C43
FW17 wrote:
09 Feb 2023, 09:31
What Joe Katz described here can indeed be the idea behind it. But a lot will depend on the vector field of the vortex itself if it will assist the underbody flow or not. What i have experienced is a specific ride height must be maintained to make these vortices work as this affects the shape. (their completely new suspension could be in relation to that and an indicator that they are using it). The lower the ride height an elliptical vortex is formed and the vortex actually flattens which actually changes the vector field of the incoming flow of the underbody. Also the diffuser flow is actually very complex as it is 3d in nature and the diffusers now expand in the vertical direction which lowers the suction on the floor. So this vortex has less to do with it now but the new regulations have raised the edges so it will eventually come into play and Alfa may make use of it, which i think would be really awesome.
FW17
168
Re: Alfa Romeo C43
Will also be interesting to see if teams are able to intentionally stall the diffuser on the straights lake they were able to do with the previous flat floor rules.
deadhead
37
Re: Alfa Romeo C43
Here they say that it has less/more compact cooling
(you can do auto-translate to English on the web)
Kyle here, who I trust more, says that this car has an enormous amount of cooling.
who right?
edit. already discussed on the previous page, sorry
BlueCheetah66
BlueCheetah66
32
Re: Alfa Romeo C43
deadhead wrote:
09 Feb 2023, 19:36
who right?
He did literally say that it was likely a high cooling setup for the tracks with more demand
EJ22B
EJ22B
Re: Alfa Romeo C43
deadhead wrote:
09 Feb 2023, 19:36
who right?
Power Unit packaging is something Sauber isn't good at compared to the other Ferrari customer Haas. Sauber has never packaged their engine cover as tight as Haas have managed to do.
Similarly, Williams isn't good at packaging the Merc power unit compared to other Merc customers like Mclaren and Aston.
It's probably something to do the restrictions created by their existing facilities and budget.
Venturiation
Venturiation
98
Re: Alfa Romeo C43
EJ22B wrote:
09 Feb 2023, 21:41
deadhead wrote:
09 Feb 2023, 19:36
who right?
So that’s why those teams have more engine problems and DNFs?
Saykas
Saykas
25
Re: Alfa Romeo C43
F1Krof
94
Re: Alfa Romeo C43
via AMUS -> floor definitely looks different to the renders.
Wroom wroom
Re: Alfa Romeo C43
So the car on presentation stage was just for later auction and was actually nowhere near the real thing. Renders were close, but different floor edges. :D
I really like how C43 looks, hope it runs well.
#Aerogimli
Venturiation
Venturiation
98
Re: Alfa Romeo C43
F1Krof wrote:
10 Feb 2023, 12:26
https://pbs.twimg.com/media/FomTRDHWcAI ... me=900x900
That Front wing :wtf: :shock:
Gridlock
30
Re: Alfa Romeo C43
Re: Alfa Romeo C43
