Aston Martin AMR23
Post Reply
zoroastar
Re: Aston Martin AMR23
NAPI10 wrote:
10 Mar 2023, 16:54
The Aston Martin Brake Tech Helping Alonso Fight in F1-
Is this easily adopted by other teams?
i doubt that it is particularly hard, but given the cost cap, teams will have to weigh whether its worthy of upgrade compared to other things. and im sure there are other pretty fancy designs rolling around the paddock too.
Vanja #66 wrote:
10 Mar 2023, 15:41
Wonderful stuff from Shub, as usual 8)
It's basically trying ti bring back the effect of the old, complicated but very effective rear brake ducts that were banned in recent times.
I really want to point out to you all thus this car has huge petential if you look at how "simple" the surfaces on the visbile part of the car are. The beam wing, the side pod, the floor edge... All relatively simple shapes!
So it's really scary what they have got going on under the floor!!
Juzh
161
Do we have any pictures of alonso's steering wheel?
delsando53
no but there is an onboard helmet view
Juzh
161
delsando53 wrote:
12 Mar 2023, 14:36
Thanks, this was helpful. Using helmet view I was able to read out what's written on this white button:
I'm fairly positive it's "K0", basically mgu-k kill switch. I've seen him using it quite often in later stages of bahrain GP, specifically in entry to T12. It looks like Alonso didn't like predefined energy deployment settings and just manually disabled mgu-k for that corner. To save tyres of course.
Juzh wrote:
12 Mar 2023, 21:13
delsando53 wrote:
12 Mar 2023, 14:36
https://i.imgur.com/kZQpUSM.png
It was mentioned by Valterri Bottas that the Mercedes PU was much more "automatic" in its deployment operation. Perhaps that is to the detriment of Alonso.
I also noticed Alonso was having so much wheel spin in 3rd gear when he was pushing. In spite of his great result, you can tell that things were quite un-optimized in terms of steering, and deployment.
Juzh
161
12 Mar 2023, 21:17
Juzh wrote:
12 Mar 2023, 21:13
delsando53 wrote:
12 Mar 2023, 14:36
It was mentioned by Valterri Bottas that the Mercedes PU was much more "automatic" in it's deployment operation. Perhaps that is to the detriment of Alonso.
I wouldn't say detriment. Basically with mgu-k deploying you go too fast and either have to lift = wasted energy, or stay full throttle and have a lot of tyre scrub and burning them out sooner than necessary. I've noticed speed stays constant immediately after he presses the button.
Juzh wrote:
12 Mar 2023, 21:23
12 Mar 2023, 21:17
Juzh wrote:
12 Mar 2023, 21:13
I thought you could change mgu-k deployment on the fly? That it wasn't part of a map.
Juzh
161
diffuser wrote:
13 Mar 2023, 09:03
Juzh wrote:
12 Mar 2023, 21:23
12 Mar 2023, 21:17
I'm not sure what you mean.
edit.
ok, now I get you, you mean ICE map? No, energy deployment isn't part of it, but it looks like mercedes didn't program a suitable automatic deployment plan in this case.
I've seen alpha tauri drivers also use this tactic in the past many times. On honda engines it's called "anti-deploy". Interestingly I've never seen or heard red bull drivers use it.
Juzh wrote:
13 Mar 2023, 13:32
diffuser wrote:
13 Mar 2023, 09:03
Juzh wrote:
12 Mar 2023, 21:23
edit.
I think the team assigned to Aston from Merc would do that. It's obvious that cars are going to have different characteristics, so they're gonna deploy differently. Williams might want to take advantage of their straight line speed and deploy more on the straights. Also when you're trying to pass a car you might need to switch up the deployment on the fly to save in one place to use it somewhere else.
vorticism
323
05 Mar 2023, 11:24
The upper A-arm is rather high up; has Dan Fallows brought longbow thing to Aston Martin?
𓄀
vorticism wrote:
15 Mar 2023, 22:09
05 Mar 2023, 11:24
https://i.imgur.com/omyP96h.jpeg
I believe so.
Chuckjr
36
Contact:
Does that offer a longer length of travel for the wheel because (I assume) the tire moves kinda diagonally up and back instead of straight up and down? Sorry if I’m seeing it wrong.
Watching F1 since 1986.
I think it allows a smaller bulkhead and cleaner aero at the arm and under the bulkhead too.
Post Reply
