Aston Martin AMR23
Post Reply
Zynerji
110
Re: Aston Martin AMR23
carisi2k wrote:
26 May 2023, 08:18
25 May 2023, 18:33
https://i.imgur.com/8FmwMXb.jpeg
There is some tricky geometry/discontinuity going on with their flap's joint with the rest of the wing. Hard to say exactly what they're doing
This is the sort of thing that needs to be banned because it goes against the purpose of the new regs and creates the dirty air the new regs were meant to remove.
This is the sort of thing that keeps several of us interested in F1 at all, however.
25 May 2023, 18:33
That lateral flow is likely the purpose of this detail.
Zynerji
110
Vanja #66 wrote:
26 May 2023, 15:14
Excellent visualisation of strong lateral flow at flap tips.
Is it even reaching the backside of the upper flap? Or is there just a protective laminar flow from the slot-gap that pushes the flowvis into the rooster tail without touching?🤔
Contact:
Zynerji wrote:
26 May 2023, 15:27
The very top of the flap tips is basically stalled, but in this case it most likely means the wing is working at the very maximum of its potential. E.g. they could cut it out to reduce drag, but this would likely hurt the tip vortices and reduce downforce.
#Aerogimli
Zynerji
110
Vanja #66 wrote:
26 May 2023, 16:23
Zynerji wrote:
26 May 2023, 15:27
Could the stalling effect work like the F-duct?!?! :o
Contact:
Zynerji wrote:
26 May 2023, 16:47
With flap down, not really, it's likely a permanent separation bubble. With flap up, it could essentially stall the whole flap tip and reduce drag vs flap down flow. However, I expect this is the same for any wing design now that we have this transition bend between wing and endplate.
#Aerogimli
Zynerji
110
Vanja #66 wrote:
26 May 2023, 16:54
Zynerji wrote:
26 May 2023, 16:47
Thanks
March
April 29th
May 26th
BassVirolla
Tweet without any technical value, but nice view of the slides.
Venturiation
98
Top floor
KimiRai
194
No view from below yet?
Venturiation
98
KimiRai wrote:
27 May 2023, 23:18
Last chance is tomorrow if something happens on the track
BassVirolla wrote:
27 May 2023, 14:32
https://twitter.com/alomgc14/status/1662425677369409540
This formula's optimum shape is make side pods as wide as possible, with deep undercut and a gully?
carisi2k
26 May 2023, 15:23
25 May 2023, 18:33
Except it is coming at the expense of what these new rules were made to achieve. The goal was to get rid of dirty air and these things create the dirty air and so they should be eliminated so as to achieve the goal of reduced dirty air.
carisi2k wrote:
29 May 2023, 04:00
26 May 2023, 15:23
25 May 2023, 18:33
Not sure about that. From the pic posted from Citrix... looks like they're trying keep the air flow from the point of the upper rear wing?
Post Reply
