Red Bull RB19
sour
sour
Re: Red Bull RB19
sorry if this is a re-post
vorticism
323
Re: Red Bull RB19
Single beam wing?
π“„€
Stu
Re: Red Bull RB19
vorticism wrote: ↑
Fri Mar 17, 2023 10:06 pm
https://i.postimg.cc/PfY2RbXh/racefansd ... 9-24-4.jpg
Single beam wing?
And what looks to be quite aggressive anti-squat geometry (judging by the top wishbone).
vorticism
323
Re: Red Bull RB19
Stu wrote: ↑
Fri Mar 17, 2023 10:17 pm
vorticism wrote: ↑
Single beam wing?
Mirror opposite of the front suspension.
π“„€
Re: Red Bull RB19
vorticism wrote: ↑
Single beam wing?
Single element is what they used for Monza/spa/Jeddah/baku last year so that makes sense
vorticism
323
Re: Red Bull RB19
sour wrote: ↑
Fri Mar 17, 2023 9:58 pm
https://cdn-9.motorsport.com/images/mgl ... tail-1.jpg
+1
A reservoir or venting?
π“„€
Re: Red Bull RB19
sour wrote: ↑
It isn't thanks for posting!
Stu
Re: Red Bull RB19
vorticism wrote: ↑
Fri Mar 17, 2023 10:32 pm
sour wrote: ↑
[url]https://cdn-to 9.motorsport.com/images/mgl/2y31OQX6/s8/red-bull-racing-rb19-detail-1.jpg[/url]
+1
https://i.postimg.cc/kGDmcjSQ/Screen-Sh ... -12-PM.png
Gearbox cooler return?
Edit…
Scrap that idea ^^^!
Looking at the OP of that picture it goes into the rear crash structure, so more likely to be for rear rain/warning lights and DRS actuation.
230
Re: Red Bull RB19
vorticism wrote: ↑
sour wrote: ↑
+1
It can be just an access hole for a spanner or ratchet to unscrew the rear crash struxture fasterners.
vorticism
323
Re: Red Bull RB19
+1s to all. Since it is going into the crash structure (aft of the wing pylon) and it's connected to a metal tube it might be the crankcase vent, which for a few seasons now they've had to terminate at the rear of the car often alonside the CS or within it. The shape is unique, it goes from tubular to a very wide flange, which might be an aero decision. Many cars have a port around the rear light which usually is the vent. RB19:
diffuser wrote: ↑
Sat Mar 18, 2023 10:33 am
Here there's two; crankcase and...?
Back to the flanged tube, in the full image you can see the tube goes all the way forward; sleuths should be able to find RB18/19 engine photos showing where this tube goes on the engine side.
sour wrote: ↑
π“„€
Re: Red Bull RB19
vorticism
323
Re: Red Bull RB19
+1 Sevach.
Good photo from RaceFans/XPB:
The longbow and floor spring are visible. Also the air probe unit is revealed. For the first time (?) we can see the rear upper arm attachment unfaired. It's a rigid stem extending out from the monocoque. Probably terminates in a flexure which means that whole arm assembly has no traditional pivots.
π“„€
Re: Red Bull RB19
No longer using belleville washers as the floor spring?
vorticism
323
Re: Red Bull RB19
Motorsport.com
π“„€
230
Re: Red Bull RB19
vorticism wrote: ↑
Sat Mar 18, 2023 6:25 pm
+1 Sevach.
https://www.racefans.net/wp-content/upl ... 0-21-1.jpg
https://i.postimg.cc/NFNRvwQf/Screen-Sh ... -05-PM.png
What's 8nteresting about that rear upper arm is it seems the pivot point is off the body. So effectively a short arm pivoting around 3 inches away from the monocoque.
