2026 Aerodynamic & Chassis Regulations
FW17
170
Re: 2026 Aerodynamic & Chassis Regulations
Vappy wrote:
Sat Dec 14, 2024 1:27 pm
FW17 wrote:
Fri Dec 13, 2024 12:35 pm
wuzak wrote:
Fri Dec 13, 2024 11:50 am
They will be very fast at accelerating - that's where the maximum ERS deployment will be used the most.
It will be like the LMP1s from the 2010s. Though, perhaps, without the speed plateauing very early on the straight.
Like the porsche 919 evo
What a machine. You could hear that bad boy clear as day when it fully deployed
Look at the deployment strategy by Porsche engineers. It would be similar to F1 race, battery need not be fully charged, Electrical energy regenerated and used at every instance.
bananapeel23
Seanspeed wrote:
Thu Dec 12, 2024 10:53 pm
bananapeel23 wrote:
Thu Dec 12, 2024 10:03 pm
They will just be really slow under acceleration, like laughably slow, but that is a large part of why they will produce good racing.
That's not actually good for overtaking. It means a stronger concertina effect that means it'll be farther down the straight before the car behind starts going faster than the car ahead, meaning there's a shorter distance to actually get alongside.
I think we'll be clamoring for DRS back again before too long. DRS got a bad rap, but it was so often poorly balanced in terms of how much of it was allowed on a given track, and was especially bad when it was given to cars on back-to-back longer straights.
Stronger concertina, but more time on the straight and the ability to deploy a ton of ERS for the following car, leading to similar speed deltas, but at the cost of losing a bunch of deployment on the following lap, allowing reovertaking.
bananapeel23
I don't think they will be able to deploy the full 350KW in traction zones. They will still be slower under acceleration, even if that is where they will lose the least (apart from the end of straight due to the loss of drag).
bananapeel23
deadhead wrote:
Fri Dec 13, 2024 12:44 am
Tell me we will be able to avoid this sort of monstrosity?
https://ibb.co/3pc22Dg
Monstrosity?
It's beautiful and functional! The bargeboards were an engineering marvel.
Holm86
247
FW17 wrote:
Sat Dec 14, 2024 2:02 pm
https://www.youtube.com/watch?v=PQmSUHhP3ug
They're not gonna be anyway near the 919 Evo.
The maximum harvest per lap is 8.5 MJ, thats 24 seconds of full power per lap.
And the maximum charge of the ES at any given moment is 4 MJ, meaning that you can only run full power for a maximum 11.5 seconds at the time.
I doub't these engines will run at full power very often. And full power from the new 2026 engines will be around 750kw = 1006 hp, at a maximum. The 919 Evo had a combined HP output of 1160hp
Looks like diffuser strakes have been allowed with issue 10 of the rules, along with increased freedom with dimensions of diffuser sidewalls
Also from Qvist_Designs
Feels like the aerodynamics of the new ruleset are going more complicated again after the relative simplicity of 2022-
Seanspeed
Seanspeed
bananapeel23 wrote:
Mon Dec 16, 2024 10:39 am
Less time on the straight given the general lower drag nature of these newer cars, actually. This will actually make it worse.
Slower initial acceleration, but once they do get up to speed, that low drag aspect is gonna shorten the distance from that point on to the braking point. It's literally going to exacerbate the concertina effect in terms of making it super hard for the following car to get a chance. Especially out of any slower corners.
Vappy
Vappy
Thu Dec 19, 2024 9:13 pm
https://i.imgur.com/Znxpghb.jpeg
Looking at that floor and diffuser, I suspect teams will want to put the rear ride height up nice and high like in previous generations to create an effectively larger diffuser?
FW17
170
Holm86 wrote:
Mon Dec 16, 2024 11:17 pm
Engines have not been developed since 2021, Max power from engine could be around 450 KW
4MJ limit is the maximum allowed discharge at a time, They can recharge and deploy multiple time during the lap.
FW17
170
Why is the gearbox represented like this? wouldn't they follow current size of if not even slimmer?
If the idea of the rule set is to have airflow straight or inwash at the entrance of the floor near the cockpit, why is the floor plank step curved like in the current rule set?
DDopey
DDopey
So with all this more complicated aero, will that create more air disturbance ? And if then also power deployment becomes an issue, will there be any overtaking at all ?
468
FW17 wrote:
Mon Dec 23, 2024 11:36 am
But maximum deployment is reduced above 290kph as well.
At 330kph they will be down to 150kW deployment.
468
The ICE will.
The MGUK cannot due to regulations (and energy recovery limits).
The 919 EVO also had a much larger battery and an MGUH along with the MGUK.
468
bananapeel23 wrote:
Mon Dec 16, 2024 10:40 am
Current cars cannot put all their power down in traction zones at the moment either.
They will likely need to use the full 350kW in accelerating in some corners due to the turbo being off boost.
FW17
170
From 2006 to 2013 cars had about 750hp. 2026 engine and the mgu can match that for the entire lap.
The difference is the 150kg of additional empty weight in comparison to 2013 cars. But starting weights in 2013 was 800 kgs, 2026 cars would be 830 kg just 30kg difference.
