Concept power units from 2030
trinidefender
trinidefender
318
Re: Concept power units from 2030
Why not turbo compounding? Lose the complexity and safety issues of the high voltage/current of the current hybrid systems while still retaining a lot of the energy recovery using an exhaust recovery turbine. It wouldn’t even weigh that much or take up much space.
A V10 with a recovery turbine feeding power back to the crankshaft sounds like a fine idea
Chuckjr
37
mzso wrote:
Fri Apr 04, 2025 12:46 pm
How about something in this vein?
https://www.youtube.com/watch?v=RiZbjAuKk4A
I posted that exact video in the other similar thread to this one.
https://www.f1technical.net/forum/viewt ... 7&start=15
Watching F1 since 1986.
mzso
mzso
67
Tommy Cookers wrote:
Fri Apr 04, 2025 7:46 pm
well they could have an N/A V10 with an MGU-H
something for everyone
What would be the point (from a technical point of view) of having a V10 with an MGU-H/turbo?
mzso
mzso
67
trinidefender wrote:
Sat Apr 05, 2025 5:16 am
Wouldn't that just be inefficient, with no ability to store energy. So no gains by using an electric boost at the right time. And no fixing of the turbo lag.
648
mzso wrote:
Sat Apr 05, 2025 8:51 pm
recovery of energy from the exhaust (without affecting crankshaft power)
though crankshaft power can also be traded for electrical power - and vice versa
recovery via a mechanical route ie 'turbo-compounding' is less versatile and increases PU inertia and gearshift time loss
mzso
mzso
67
Sun Apr 06, 2025 12:32 am
The point of contention is the V10, if you have turbocharging and H. Seems completely counter intuitive.
mzso
mzso
67
While on the the topic of smaller/lighter engines. I wonder why no-one ever mad an X-4, or X-8 engine. (For racing anyway)
648
mzso wrote:
Sat Apr 12, 2025 10:00 pm
... I wonder why no-one ever mad an X-4, or X-8 engine. (For racing anyway)
too much vibration
too many camshaft drives
too many machining operations in manufacture
mzso
mzso
67
Mon Apr 14, 2025 7:33 pm
too much vibration
Vibration? The opposing pistons could combust at the same time. Which is very good for vibration.
Are the other to reasons much relevant to racing?
648
mzso wrote:
Mon Apr 14, 2025 9:05 pm
too much vibration
there are no opposing pistons ie opposition is only partial due to the angles chosen
vibration is to do with the motion of masses - it has nothing to do with combustion
mzso
mzso
67
Tue Apr 15, 2025 12:33 am
too much vibration
Pairs of pistons are quite obviously fully opposite each other, as in boxers.
You're overly nitpicky. Of course combustion matters. If piston pairs don't move symmetrically and fire at the same moment, the forces don't cancel each other out.
648
mzso wrote:
Tue Apr 15, 2025 4:53 am
Pairs of pistons are quite obviously fully opposite each other, as in boxers....
fully opposite aka opposed means when a piston is going east another is going west
(this requires more than one crankpin)
'quite obviously' your pistons aren't moving like that
(you have only one crankpin)
yours is equivalent to two very vibratory twin cylinder engines 'joined' at an intermediate and arbitrary angle
the outcome is still vibratory even with crankshaft counterweighting
only if joined at 90 deg (and counterweighted) can there always be in sum zero force ie no vibration at any frequency
so yes a 90 deg radial 4 will be smooth (as will be eg a 72 deg radial 5 cyl etc)
yes in the 1930s there was a GP car with a 16 cylinder 2 stroke aircooled radial - it overheated
Last edited by Tommy Cookers on Wed Apr 16, 2025 12:36 pm, edited 1 time in total.
toraabe
toraabe
Forget that. Two stroke with turbo instead..
mzso
mzso
67
Tue Apr 15, 2025 2:28 pm
only if joined at 90 deg can there be in sum no vibratory forces at engine frequency
so yes a 90 deg radial 4 will be smooth (as will be a 120 deg radial 3 cylinder or a 72 deg radial 5 cyl etc etc)
yes in the 1930s there was a GP car with a 16? cylinder 2 stroke ? aircooled radial
Well, that's the only animation I found. So I said it with words.
So it could be compact and low vibration. Then the question is whether it matters for racing (or other high performance) applications that it has a lot of camshafts and requires more machining.
648
mzso wrote:
Wed Apr 16, 2025 10:25 am
no it couldn't
it could be compact or low vibration
a 90 deg X4 could have perfect balance but isn't compact or well-suited to car installation)
(and in correction of my earlier post actually a 120 deg 3 cylinder radial doesn't have perfect balance)
a compact X4 wouldn't be close to 90 deg and so would vibrate eg more than any car (3 or more cylinder) engine
