mzso wrote: ↑Tue Apr 22, 2025 6:08 pm
Would the separate compressor/harvester have enough advantages to worth the extra weight and complexity?
Any really strong reason to not make the engines smaller/ligther with less cylinders?
The electric compressor is to have zero turbo lag and mostly to greenwash the engine so Honda, Mercedes etc are happy
V6 is for sound and for Ferrari (originally the actual ICE project was a 4 cylinder in line, Ferrari asked for V6)
an electric turbo can work at 48v, so you don't need high voltage cables and is al lot lighter than a kers
BTW
i think that current PUs will became simpler if you split turbo and compressor; except maybe for lean combustion on actual PU the MGUH is the most difficult part to design and to fine tune
that because is always a compromise between energy harvesting and air compression; if you split the turbine and the compressor, each with a dedicated electric motor/generator there is no need of compromise in design and the fine tune becomes trivial because each part can do what is designed for at its best
