2025 McLaren F1 Team
Venturiation
Venturiation
102
Re: 2025 McLaren F1 Team
that late braking from piastri showed who the better driver is under pressure
BMMR61
Darth-Piekus wrote:
Mon Jun 16, 2025 9:10 am
Ill say it to the end of time. Mclaren needs special conditions to be the best car just like last years car. Oscar Piastri is making the difference this year.
I'd say the opposite, that in special circumstances the McLaren isn't the best car. The 24 race weekends at different types of tracks and variable temperature and weather produces a real test so that at the end of the year it should be clear who has the best car.
FittingMechanics
FittingMechanics
16
The car was probably best or close to it in Canada. This was masked for four reasons:
1. Cars qualified in P3 and P7 with the car with better tire management in P7
2. Piastri lost a position at the start
3. Norris was on an alternate strategy
4. Team didn't bring two mediums
If we got a slightly different quali, let's say just Norris starts P3 with PIA in P4, this is probably a victory for Norris.
CjC
CjC
FittingMechanics wrote:
Mon Jun 16, 2025 11:36 am
Agreed.
Just a fan's point of view
CjC
CjC
BMMR61 wrote:
Mon Jun 16, 2025 10:28 am
Me too.
The MCL39 has been the best car over the last 10 races.
It has the least amount of weaknesses but when the the tarmac is smooth and not very abrasive it’s advantage is negated
Watto
Watto
I thought Lando looked the better of the 2 most of the weekend.
I get it too the 2 critical times he didn't show it was Q3 when the pressure was on and the crash.
I get it WC don't make those mistakes when the pressure is really on, it will be interesting to see how Lando reacts in future races. One thing I have been a little critical of Lando is he doesn't often try unusual moves to catch an opponent by surprise he did with Oscar on the weekend which I though was a positive.It was much unlike Lando and care I say it something I thoughts straight from the Oscar playbook. And something I didn't think we really saw with Oscar this week.
Clearly misjudged the move on the start finish straight and paid the price - got too desperate and took too big a risk but I thought the mindset to try the moves was right.
Thought Lando was the quicker driver most of the weekend - it was Oscar the almost put the car in the wall in FP3.
Oscars calmness is a huge asset though and I though that was impotant to but I thought there were some positives of Lando too
deadhead
70
Venturiation wrote:
Mon Jun 16, 2025 9:39 am
Why was he so slow in the race? It reminded me of last year where he was slower than NOR on race pace at multiple tracks
FittingMechanics
FittingMechanics
16
Watto wrote:
Mon Jun 16, 2025 12:11 pm
Lando made a mistake there, but I think he was well aware that it is very likely that he gets pushed wide if he goes around the outside. Just like Piastri went late on the brakes for the final corner, it is likely he would have went deep into T1, Norris then has to bail off track and concede the position back.
I am 100% in favor of him always going toward the inside, that is a massively advantageous with the current racing rules. But obviously, you can't run into people.
Lando should have kept the inside before last corner and then he would take the place.
mwillems
46
deadhead wrote:
Mon Jun 16, 2025 12:26 pm
He just is sometimes. But he's also been legitmately faster in some races this year. Another step forward for him.
The ebb and flow is normal but I agree that this weekend he did drop his standards more than you'd like. That said, Oscar was held up by Kimi and then by some unfortunate traffic timing. In clean air the gap to Lando wasn't so big. But at the same time, Lando was clearly better in dirty air than Oscar was. I suspect Oscars style, leaning on the rears, might just not be compatible with a low grip track - and he wasn't able to adjust.
-Bandit
Emag
Emag
Finally saw the race as a replay. Quite a bit more boring than I thought it would be after quali. In the end, track position was critical and the tires were degrading like crazy. McLaren tried, but there wasn't a big enough pace advantage to make an impact with such poor track position after lap 1. Quali should have been prioritized, maybe something for them to look into and evaluate is the reasoning why they were against using a set of mediums in Q3.
I was surprised with how good Mercedes were around here, but they have been quite decent in Canada these last couple of years, so I will reserve judgement of improved pace/deg until we've seen a couple more races from them. On the other hand, deg on the RedBull, especially on the earlier stints with heavier fuel, was way more than I expected them to have. So that was also a surprise.
Oscar also showed that he is lacking something in tire management to Lando still, although its no where near as bad as it was last year. In any case, if the cars were reversed, I think Lando would have made the podium at least, but I doubt he would be able to overtake Max on track to go beyond that anyway.
I guess there is no need for me to comment the incident at the end. Lando already accepted responsibility, which was the only correct outcome. A very very poor showcase of decision-making in a racing situation and it's not the first time he does it. I don't know why Lando tries to put his nose where there is no room for it. He did it in Suzuka as well against Max on the pit exit. The last time this maneuver of his worked was back in 2021, Monza, where he overtook Leclerc by going partially off-track. And that only happened because Leclerc was nice enough to give him enough room. He should stop going for these pointless and dangerous moves. Could have ended in a double dnf.
Developer of F1InsightsHub
BMMR61
Oscar came pretty close to getting the overtake on Antonelli in the closing stages. Kimi had a whole new PU which are normally a few % stronger - not sure how old the unit in Oscar's car, could this have contributed to this "cork in the bottle" effect as Oscar clearly had pace in the last stint?
avantman
avantman
and do you really think Mclaren was not the best car in Canada? What special conditions are you referring to? Mclaren had the car good enough to win every race this year, wet or dry, cool or hot. Most definitely they made a very big and costly strategical mistake of not qualifying on medium. On soft they were the fastest car easily despite both drivers not driving well this weekend. Norris was quite clearly again faster than Piastri during the race and was looking after his tires better. The tragedy of Mclaren this year is their faster driver near always starts behind and fights through traffic.
CjC
CjC
Not sure why Lando didn’t use a medium in Q3- probably a good job he didn’t but Oscar said he turned down the idea of using the medium for his last run in Q3 because he just wanted to keep it consistent after multiple runs using the soft tyres
avantman
avantman
Oh, and by they way they came out again fuelled for 2 push laps on their first run in Q3. Oscar set 1:11.273 carrying fuel for two extra laps. Do we know how much does it cost roughly in terms of lap time? a couple of tenths?
CjC
CjC
0.05 to 0.1 of a second. Oscar qualified with a 1.11.1 didn’t he?
