Pics of rear upright seem to pretty much confirm separate fwd and aft links on upper “wishbone”, as detailed here:SilviuAgo wrote: ↑Thu Apr 17, 2025 7:28 pmMore pics tks to Autoracer.it
https://autoracer.it/wp-content/uploads ... x1364.webp
https://pbs.twimg.com/card_img/19128195 ... me=900x900
Yes, true, also in Bahrain test days they tried this RW configuration, and in Melbourne only on Lando's car, in FP1 just to revert on FP2 to the RW config used for the rest of the weekend. As you said, influenced by the incoming weather.
Would that reduce "scrub" under full-ish compression aero load situation ?ing. wrote: ↑Fri Apr 18, 2025 5:00 amPics of rear upright seem to pretty much confirm separate fwd and aft links on upper “wishbone”, as detailed here:SilviuAgo wrote: ↑Thu Apr 17, 2025 7:28 pmMore pics tks to Autoracer.it
https://x.com/engdesigning/status/19086 ... 5rN71eTA2g
Although this could be used to create a more outboard “virtual” upper pivot, or joint, I don’t expect this will change either camber gain or scrub characteristics. The latter are mostly influenced by roll center (or instant center) height and wishbone effective lengths.Farnborough wrote: ↑Fri Apr 18, 2025 8:14 amWould that reduce "scrub" under full-ish compression aero load situation ?ing. wrote: ↑Fri Apr 18, 2025 5:00 amPics of rear upright seem to pretty much confirm separate fwd and aft links on upper “wishbone”, as detailed here:SilviuAgo wrote: ↑Thu Apr 17, 2025 7:28 pmMore pics tks to Autoracer.it
Thank you for the explanation and thought on this.ing. wrote: ↑Fri Apr 18, 2025 12:29 pmAlthough this could be used to create a more outboard “virtual” upper pivot, or joint, I don’t expect this will change either camber gain or scrub characteristics. The latter are mostly influenced by roll center (or instant center) height and wishbone effective lengths.Farnborough wrote: ↑Fri Apr 18, 2025 8:14 amWould that reduce "scrub" under full-ish compression aero load situation ?ing. wrote: ↑Fri Apr 18, 2025 5:00 am
I expect they used the separate link design to accommodate the somewhat extreme divergent angles of the fwd and aft arms.
On the front suspension—with steering involved—the virtual joint (lower in this case) may be useful in reducing steering loads and kickback:
An artificial post-edit by someone, highlighting the shapes.
Also I just noticed, this is not from this year. The marshall’s shirt says MiamiSilent Storm wrote: ↑Sun Apr 20, 2025 8:00 pmMclaren floor
https://pbs.twimg.com/media/Go_91NUWMAA ... name=large
Good catch, I was so excited to see that Mclaren floor that I missed the background.Emag wrote: ↑Mon Apr 21, 2025 2:34 pmAlso I just noticed, this is not from this year. The marshall’s shirt says MiamiSilent Storm wrote: ↑Sun Apr 20, 2025 8:00 pmMclaren floor
https://pbs.twimg.com/media/Go_91NUWMAA ... name=large![]()
