2026 Regs potential delay - Discussion
Will they be delayed?
Yes
10%
No
74%
They will be scrapped
6%
They will be heavily modified
11%
Total votes: 72
Richard C
Re: 2026 Regs potential delay - Discussion
basti313 wrote:
Tue Mar 25, 2025 8:23 pm
Richard C wrote:
Tue Mar 25, 2025 7:11 pm
basti313 wrote:
Tue Mar 25, 2025 5:35 pm
So why a V10? Would be roughly double the weight of a R4 Turbo...
Futhermore: A proper Hybrid system like the initial KERS has a weight penalty of 30kg and much more power on modern architecture than back then. As seen in Indy car, this improves racing, generates interesting overtaking options. I would always rather sack DRS for an interesting KERS, maybe electronically replicating the necessary Mario Kart feature of it.
Your not asking me, but will swing at an answer...
Why V10? Nostalgia for the previous NA V10. Not that anything is wrong with that. Regarding "only 30kg". If the sport is looking to reduce weight then it all adds up and it all has to be considered for a diet. If we wanted to drop car weight 100kg, then the 30kg is almost 1/3 of that answer. Granted it does provide band-aid for passing difficulty and a small KERS could be part of a future solution.
Richard
Well, the less fancy materials in the 2026 engine add around 15kg on the V6 alone. The same happened on the V8 to V6 change, the ICE simply got heavier even though it was smaller. If you look at the current regs...the increase to a V10 on the same material is simply heavier than all the Hybrid stuff. I would expect a V10 easily crosses 200kg, while the V6 turbo next year has a min weight of 130kg. ES + MGUK is currently at around 40kg...
V10 just does not work without adding substantial weight.
I don't follow the material exclusion regulations closely, but when checking just a few minutes ago can see some extra exclusions from 2025 to 2026. I also notice an increase in minimum weight for various PU components. For example piston assembly increases from 300g to 350g. I don't know if that is done to accommodate for material restrictions or if it's a general durability/cost reduction exercise. Regardless, the regulations alone have a part of making the PU heavier (apples to apples). And yes, a larger displacement NA is going to weigh more than a smaller displacement turbo (given equivalent power).
As with many things I can imagine future tech specs will have conflicting goals. So it seems NA V10 (likely high revving) for sound/nostalgia reasons, but as you say, that may be heavier than a small turbo and contrary to other goals of overall weight reduction. And given safety improvements, the cars are never going to be as light as they were a few decades a go.
Richard
To paraphrase Mark Twain... "I'm sorry I wrote such a long post; I didn't have time to write a short one."
Holm86
249
Richard
V10 because to me that was the best sounding engines in F1 ever, and I know a lot of people agree with that.
And contrary to what many people keeps saying, sound IS important in motorsport, and a part of what makes it special.
Back in the day, a V10 at 19.000 rpm was a unique sound to Formula 1, no other racing series used a similar engine.
Today many racing series has R4, V6, V8, Turbo/NA etc.
And creating a high reving, high power naturally aspirated engine is still a great engineering task, that many engineers would love to work on.
Regarding the weight, the last Ferrari V10 from 2005 the Tipo 055 had a weight of 90 kg, and yes a modern V10 would have to be beefier for reliability to survive more that a couple of races, but that should be dooable at much less than the 200 kg you're talking about.
And the hybrid systems doesnt only add weight, they also add bulk, but if they could engineer a tiny electric motor and tiny battery package with around 100 hp, and use it as a push to pass instead of DRS that would be fine with me ...
Chuckjr
37
100% Holm86. =D>
Watching F1 since 1986.
TeamKoolGreen
TeamKoolGreen
-5
Richard
The numbers were posted on the Autosport forum a year or so ago and its not even close. A proper V10 with no turbos, no batteries and nothing associated with hybrid would be way lighter. Not to mention the less efficient cooling and aero because of the space all of this stuff takes up, as mentioned in Adrien Neweys book.
TeamKoolGreen
TeamKoolGreen
-5
Jason Hassett made a good point about the 2026 regs. They were all about Porsche and Audi coming in. That is why we have these Frankenstein power units. Now Porsche is gone and Audi has cold feet. The silence of Stefano Domenicali on the 2026 regs speaks volumes. He doesn't want them any more than the fans do.
Chuckjr
37
What about a V10 oval piston? Ferrari just patented a wild design...would present good new challenges for the engineers to perfect.
basti313
basti313
TeamKoolGreen wrote:
Thu Mar 27, 2025 7:08 am
Richard
So, what are your numbers? I think this calculation can only work if you neglect the fact, that the V6 ICE itself without turbo and ERS is now as heavy as the V10 back then. A V10 today would be substantially more heavy.
For cooling: Of course it is more difficult. But what is the issue with difficult?
Don`t russel the hamster!
KimiRai
KimiRai
301
BBC Sport's Andrew Benson:
A leading team boss told BBC Sport on condition of anonymity that there have been "zero discussions" of this idea in the group of F1 stakeholders.
It takes time - years - to agree engine rules.
It would probably be two years before a full agreement could be reached. Then the manufacturers would need the same time again to develop and build the engines. Which would take F1 to the end of 2029. Which is only a year before the new rules are due to expire anyway.
As one team boss puts it: "I think this will all peter out, and it will just end up becoming: 'What will 2031 look like?'"
https://www.bbc.co.uk/sport/formula1/ar ... ed4jk7eeeo
650
basti313 wrote:
Thu Mar 27, 2025 10:12 am
. .... A V10 today would be substantially more heavy.....
we have for 2026 an increased minimum piston weight of 350 gm
guessing - this would not allow 19000 rpm or anything like any rpm the V10 campaigners imagine
people seem to have forgotten that F1 hybrid has steel pistons
Richard C
Tommy Cookers wrote:
Thu Mar 27, 2025 10:37 am
I am curious as to the rationale for the various component min weight increases? Durability? Cost savings (i.e. lower tech / less stressed = cheaper)?
Richard
TeamKoolGreen
TeamKoolGreen
-5
So heavier pistons, heavier batteries and heavier MGUK. Since the car will heavier, the crash structures will have to be heavier to account for the increase in mass. (So they can conveniently blame safety for the increase in weight again)
Lighter and nimbler cars in 2026 =D>
In 2026, F1 engines will see a weight increase, primarily due to a larger battery and increased electric power, but also due to changes in the MGU-K and other ancillary parts, moving from 151kg to 185kg.
650
Chuckjr wrote:
Thu Mar 27, 2025 8:18 am
co-planar rods were the convention eg even before Harley met Davidson
likewise articulated co-planar rods
V aircraft engine rods always were co-planar but often not articulated
the modern convention (side-by-side rods) dates from the first 'cheap' car V8 (1932 Ford)
in WW2 Ford so redesigned the RR Merlin making it worse
imo regardless of rod type the V12 doesn't have a 'rocking couple' ... because ....
inline 6s give nil resultant couple (primary and secondary) and in effect the V12 is two inline 6s superposed ....
so don't the secondary effects expected with the articulated (shorter) rods also give a nil resultant ?
(in a WW1 Sunbeam aero engine articulated rods caused vibration problems but it was a (flat crank) V8)
Honda went 'oval piston' to get 8 valves per cylinder ie a 4 cylinder engine with the total valve area of a V8
the Ferrari patent doesn't mention this aspect ?
(btw at the time this 23000 rpm GP Honda was said to have no piston rings - and a very high rpm starter)
Zynerji
111
What about a V10 oval piston? Ferrari just patented a wild design...would present good new challenges for the engineers to perfect. https://www.youtube.com/watch?v=RiZbjAuKk4A
What if they tilted the pistons and twisted the wrist pin perch to NOT be in the rocking direction? Would it help?
Greg Locock
Greg Locock
238
Tommy i agree, a V12 with a half cylinder offset between banks is two I6s, hence perfect for inertial forces. Rough figures for vibration at 6000 rpm WOT, 4 litre i6 5g, 2 litre i4 20g.
Chuckjr
37
Thu Mar 27, 2025 9:06 pm
Zynerji wrote:
Fri Mar 28, 2025 2:07 am
Well this is fascinating. I loaded in the questions from Tommy and Zynerji into Grok, and this is what it spit out.
Ferrari’s recently patented oval-piston V12 design is indeed a fascinating evolution of internal combustion engine architecture, and your question dives into the nitty-gritty of its dynamics—specifically the rocking couple, secondary effects of articulated rods, and the potential impact of tilting pistons or twisting the wrist pin perch. Let’s break this down step-by-step, exploring the mechanics and reasoning through the implications.
First, let’s establish the baseline. A traditional V12 can be thought of as two inline-6 engines sharing a common crankshaft, with the cylinder banks typically offset at a specific angle (often 60° or 65° in Ferrari’s case). An inline-6 is inherently balanced for both primary and secondary forces and moments, including the rocking couple—a rotational oscillation caused by the reciprocating masses of the pistons and rods. The primary balance comes from the 120° crankpin spacing, which cancels out vertical and horizontal forces over the engine cycle. The secondary balance, tied to the second-order harmonics of the piston motion (due to the connecting rod’s angularity), is also nullified in an inline-6 because the opposing pistons’ motions symmetrically cancel these effects. In a V12, this symmetry is mirrored across the two banks, so the net rocking couple and secondary forces theoretically remain nil, assuming perfect symmetry and no manufacturing or design deviations.
Ferrari’s oval-piston V12 introduces two key innovations: oval (or “pill-shaped”) pistons oriented with their long axis perpendicular to the crankshaft, and an articulated connecting rod system where opposing pistons share a single crankshaft journal via a primary and secondary rod arrangement. The oval pistons allow the cylinders to be packed closer together, shortening the engine longitudinally, while the articulated rods further reduce the crankshaft length by eliminating the need for offset journals for each piston pair. This is a clever packaging solution, potentially beneficial for mid-engine layouts or hybrid systems, but it raises questions about dynamic behavior.
Now, to your point about the rocking couple and secondary effects. In a standard V12 with conventional round pistons and individual connecting rods, the rocking couple is already nil due to the inline-6 superposition, as you noted. The articulated rods in Ferrari’s design shorten the effective rod length for one of the pistons (the secondary rod pivots off the primary rod rather than directly off the crank), which alters the rod-to-stroke ratio. A shorter rod increases the angularity of the rod during the stroke, amplifying secondary forces—those second-order vibrations caused by the non-sinusoidal motion of the piston. However, because the V12 retains its mirrored inline-6 structure, these secondary effects should still cancel out across the engine. For every piston with a shorter articulated rod on one bank, there’s a corresponding piston on the opposite bank, and their motions are phased to counteract each other. So, theoretically, the net resultant of these secondary effects remains nil, just as in a conventional V12.
But here’s where it gets interesting: the articulated rod design introduces a new variable. Unlike a traditional setup where each piston has its own rod of equal length, the primary and secondary rods in Ferrari’s patent have different effective lengths and pivot points. This could introduce localized imbalances or vibrations at the individual cylinder level, even if they cancel out globally. The secondary rod’s motion isn’t purely linear—it pivots off the primary rod, adding a slight lateral component to its trajectory. This could induce a small rocking motion or side-loading on the piston, potentially increasing wear or friction against the cylinder wall, especially given the oval piston’s non-circular shape, which already complicates sealing and stability.
This brings us to your suggestion: tilting the pistons and twisting the wrist pin perch to avoid alignment with the rocking direction. In a conventional engine, the wrist pin (or piston pin) is perpendicular to the cylinder axis, and the piston “rocks” slightly within the bore due to the rod’s angularity, a phenomenon known as piston slap. With oval pistons, this rocking could be more pronounced along the shorter axis, where the piston has less surface area to resist tilting. If Ferrari tilted the pistons—say, angling them slightly relative to the cylinder bore—and twisted the wrist pin perch to align it out of the plane of this rocking motion, it could theoretically reduce side-loading and stabilize the piston’s travel. The idea would be to orient the piston’s motion such that the secondary forces and any residual rocking from the articulated rods don’t amplify each other.
Would it help? Possibly, but it’s not without trade-offs. Tilting the piston changes the combustion chamber geometry and the way forces are transmitted to the crankshaft, which could affect efficiency or power delivery. Twisting the wrist pin perch might mitigate rocking along one axis but could introduce new stresses or alignment challenges, especially with an oval piston that already demands precise sealing (a known hurdle, as Honda discovered with its NR500 oval-piston engine). Ferrari’s patent doesn’t mention such a configuration, suggesting they’re relying on the V12’s inherent balance and possibly recesses in the piston skirt (as noted in the design) to manage friction and stability. However, your idea could be a refinement if testing reveals excessive piston slap or vibration from the articulated rods—something Ferrari’s engineers might already be exploring behind closed doors.
In practice, the nil resultant of a V12’s rocking couple and secondary effects should hold unless the articulated rods disrupt the symmetry significantly. The real challenge might not be the rocking couple itself but rather the piston’s stability within an oval bore under these new dynamics. Tilting or twisting could help there, but it’d require careful simulation to ensure it doesn’t upset the engine’s balance or manufacturability. For now, Ferrari seems confident in the base design’s equilibrium, likely banking on modern materials and precision engineering to smooth out any quirks. Still, your suggestion highlights a creative avenue for optimizing this wild concept further—something that could set it apart even more if it ever roars to life in a production car.
