Page 1 of 1
Suzuka cambers
Posted: 07 Oct 2006, 19:08
by Tom
Did anyone else notice the front tyre cambers on all the cars, particularely noticable on the McLarens, were very high?
Posted: 08 Oct 2006, 10:23
by joseff
McLaren seems to run harder rubber than others. The camber setup may be Michelin's recommendation for that particular compound.
Posted: 08 Oct 2006, 13:48
by tomislavp4
I think if you make the front camber high you´ll loose stability but the car will have better responce in the corners.
Suzuka is tight circuit so you´ll need some responce of your car to go in those curves like you should.
Posted: 18 Oct 2006, 18:02
by Jersey Tom
Depends on the tire's camber thrust generating capacity and general camber sensitivity. For the tires I run I use enough negative camber to offset what camber change I'm going to see in roll on a particular track.
