Renault R29
kilcoo316
kilcoo316
21
Re: Renault R29
ISLAMATRON wrote:Woah! this is big time... what about the step plane rule? This looks like the entry of a venturi tunnel
The floor doesn't have to be flat everywhere.
Otherwise you'd have a shadow plate right the way to the front wing...
I'm not sure of the locations of the rule 'boxes' though.
imightbewrong
imightbewrong
Re: Renault R29
I think its just an optical illusion, it is a cutout in the horizontal plane. So it is not higher in the vertical plane. It has (as far as I can tell) pretty much the same look as it had at the start of the season.
ISLAMATRON
Re: Renault R29
No optical illusion at all see...
but I guess wee seen it before
and it blends into the step plane very soon after the front of the sidepod
vasia
vasia
Re: Renault R29
The floor shape and cut at the front of the sidepods has not really changed. That is in-fact an optical illusion.
ISLAMATRON
Re: Renault R29
vasia wrote:The floor shape and cut at the front of the sidepods has not really changed. That is in-fact an optical illusion.
HA hA you got me... yep they just only extended the sidepod inlets down to the floor
kilcoo316
kilcoo316
21
Re: Renault R29
Ta-da.
Same here at China...
And yes, they are looking to move the stagnation point up a bit to get more air under the floor than they otherwise would... With the local accelerations, they may see some useful localised very low pressure zones around the front & bottom of the sidepod/floor leading edge.
Britain Smith
Britain Smith
Re: Renault R29
ISLAMATRON wrote:No optical illusion at all see...
There they go walking around with the floor again.
-Britain
ISLAMATRON
Re: Renault R29
that is the same pic from Monaco
vasia
vasia
Re: Renault R29
Metar
Re: Renault R29
With all the press diffusers have been getting, seems like a smart thing to put a sponsor next to it. :P
Timomies
Timomies
Re: Renault R29
Metar wrote:With all the press diffusers have been getting, seems like a smart thing to put a sponsor next to it. :P
Yeah, I said it already when the season started. I saw AirAsia sticker in some many pics back then. It was in their rear wing. :)
ISLAMATRON
Re: Renault R29
What car is this?
Scotracer
Scotracer
Re: Renault R29
It's an amalgam of R28 front wing, R29 engine cover...but the chassis? It's an R25. I'm sure of it.
Mystery solved, Watson...
Powertrain Cooling Engineer
majicmeow
majicmeow
-2
Re: Renault R29
It looks like the R28 launch spec wing...
I agree though, the chassis does look like an R25... mostly... :wtf: Did the R25 come with the chimneys and shark gills at launch, or were they mid season add-ons?
Metar
Re: Renault R29
Unlikely, I know, but could this be an ex-Piquet writeoff R29? Smooth bodywork and sharkfin, after all... But then why bother adding the flipups? :?
It's not an R25, though. The R25's sidepods were more sculpted, and had the chimneys at launch: http://www.f1-fansite.com/Wallpaper/200 ... 3-1600.jpg
