Page 1 of 4
KERS CONTROL UNIT
Posted: 24 Jan 2009, 01:45
by DarkSnape
Re: BMW KERS CONTROL UNIT
Posted: 24 Jan 2009, 01:54
by Saribro
Doesn't look any different to me than the usual electronics, that are usually in that place too. I vote inconclusive.
Re: KERS CONTROL UNIT
Posted: 24 Jan 2009, 14:27
by i70q7m7ghw
BMW have said the control unit is in the right hand sidepod though...
Posted: 25 Jan 2009, 00:45
by Saribro
It's still looks just like the rest of 'em though, knowing that it's the KERS control unit is a big "meh" to me.
Posted: 26 Jan 2009, 11:08
by scarbs
That’s not the PCU, they’re too small and the wiring too thin. I am guessing the data acquisition units for the cars initial testing.
I saw the Toyota KERS hardware laid out on a bench at Portimao. The Power Control unit (PCU) is much larger box, about 30cm x 20cm x 10cm. While the Motor Generator (MGU) is only about 15 long and probably slightly less in diameter. It was the battery that I found curious, it was an unusual shape, moulded into a arc, like a flat bottomed orange segment. This must be to make it fit between the rad ducting and monocoque. I saw the water cooling pipes for the MGU but not the electrical cables which need to run ten of amps at high DC voltage, I am told these are quite serious bits of cable.
Posted: 26 Jan 2009, 11:37
by xpensive
Does anyone know in which way the 400kJ will be controlled by the FIA, in-to or out-off, the MGU or the battery?
Posted: 26 Jan 2009, 13:39
by scarbs
From what I’ve learned from the teams; the MGU\PCU\battery will all be directly connected. The SECU will control the PCU via its usual CAN interface. The FIA will use the SECU to check that KERS has been instigated for the maximum time and has stored the maximum energy each lap, then a FIA torque sensor will detect the power re-transmitted through the drive train.
Posted: 26 Jan 2009, 13:52
by xpensive
See if I can popularize tis correctly scarbs,
The FIA will monitor BOTH the electrical energy going from the MGU to the battery during breaking, as well as the mechanical energy leaving the MGU during accelleration?
Posted: 26 Jan 2009, 14:19
by scarbs
exactly, as the rules demand both a maximum amount of energy stored as well as a maximum discharged
Posted: 26 Jan 2009, 14:44
by ISLAMATRON
outstanding bits of information scarbs, thank you, we as fans should be able to get more info like this, but sadly(but understandably) the teams are not putting it out there for everyone to see.
Posted: 26 Jan 2009, 15:43
by xpensive
Thank's scarbs! Now as for the practical use of KERS, do you figure that teams will arrange things as charging is triggered by pressing the brake-pedal and discharge by a push-thing on the steering-wheel? Or will it be a little more sophisticated than that?
Posted: 26 Jan 2009, 15:51
by ISLAMATRON
I would assume that charging would occur when engine load falls below a certain amount like say 30%.
Posted: 26 Jan 2009, 16:32
by scarbs
xpensive wrote:Thank's scarbs! Now as for the practical use of KERS, do you figure that teams will arrange things as charging is triggered by pressing the brake-pedal and discharge by a push-thing on the steering-wheel? Or will it be a little more sophisticated than that?
Thats right, the rules wont allow anythign else.
Posted: 26 Jan 2009, 17:34
by modbaraban
Can it be possible under current rules to use KERS to control braking or/and traction?
Posted: 26 Jan 2009, 17:47
by scarbs
modbaraban wrote:Can it be possible under current rules to use KERS to control braking or/and traction?
Nope, I checked with the tech directors and as the system is controlled by the secu any funny business under braking or accelleration is strictly forbidden.
