Page 1 of 25
Over and Under or around the sides
Posted: 22 Apr 2009, 20:33
by greenpower dude reloaded
I've been working over the Off season on my latest Electric Car and underneath the chassis is by far the most efficient I've made.
Due to time restraints though we've been unable to mould the bodywork as planned and have been forced to make a temporary ply body in Brawn colours. To do this we used some templates made for the mould and fibreglass taped them to some 4mm ply.
ANYWAY!
My question is;
Is it better to direct air over and under the car in a cambered aerofoil (60mm ground clearance) or is it better to direct it round the sides. I've always been lead to belive the sides but recent figures have made me think over and under could be better.
What do you all think?? i'll (tryyy) to post some pictures later, hopefully you BrawnGP fans will approve :P
Re: Over and Under or around the sides
Posted: 22 Apr 2009, 20:57
by PNSD
Hmmm, I guess it depends.
Road cars prefer around the sides, I guess thats because it is better than the underbody and going over a steep windscreen.
For an aerofoil though I believe over and under would be best :)!
Posted: 22 Apr 2009, 21:44
by wesley123
It is about where it would fit right.
We dont know how the car looks so we cant say it actually, if it is an formula style car it is about where the air is coming from and where it is flowing.
Posted: 22 Apr 2009, 22:14
Your quite right wesley here are a couple of pictures
Unfortunately I haven't got any better pictures than that but if you use your imaginations a bit.
Imagine the tail (shown in the top pic) attached to the rear and the top fully attached.
also worth noting is that the body is still awaiting a bit more paint
Posted: 22 Apr 2009, 22:26
by Gecko
It depends on what you want to achieve. If it's downforce you want and your underbody is really smooth, you might want to take advantage of the venturi effect by sealing the sides and directing and accelerating the air underneath the body. If your underbody is exposed, then you might actually want to seal off the front of the underbody as well, in order to direct the air around and over the car.
Regarding the question of directing the air around rather than over the car; unless you use dams or winglets, you just might notice that the air will tend to do as it damn well pleases ;).
Posted: 22 Apr 2009, 23:26
Sorry I suppose I ought to tell you a little bit about the series.
Basically we're given 4 12v 75ah(50ah in reality) batteries only being allowed two on the vehicle at any one time.
We're also given a 240watt motor which we run nearer 500w and travel at speeds of up to 45mph. The greatest distance covered over 4hours wins. So its purely an efficiency challenge. So no downforce required. we almost have too much grip as it is anyway!
We're no longer allowed fully enclosed cars so im looking for the lowest drag shape possible with four wheels.
Posted: 23 Apr 2009, 01:57
by Giblet
How many decks does your diffuser have? :)
It looks to me in your case that there would be more work involved, and more weight, to get the air directed around the sides.
no idea if those factors would cancel out gains from directing air around the sides.
Posted: 23 Apr 2009, 02:06
by Jersey Tom
That general body shape looks like it will generate significant lift.
A la VW Beetle.
I wonder if putting vortex generators on the top would help, as given how abruptly the rear tapers down I'd think it would generate a decent wake as it is.
Also, given that you're not looking for DF maybe running a Nascar-style splitter on the front to direct all the air around the car would cut down drag.
Posted: 23 Apr 2009, 02:11
by Giblet
That would be good if he is going for efficiency, and considering he has an excess of grip at this time....
Crank the tire pressure and float on contact patches the size of dimes.
Posted: 23 Apr 2009, 11:49
Vortex generators could indeed make a difference thats a very good point, it doesnt actually taper away quite as quickly as you think, I think when I worked it out it was within the general 15/16deg(depending on who you ask) rule which states anything greater than that will cause turbulence. It could be foreshortenning that makes it appear steeper and of course the fact the tail isnt really attached it will follow the line of the rest of the body when all together.
I would take more pictures but i'm 150miles away at the moment. I'll get some more on sunday when it hits the track.
I agree it will generate a fair amount of lift but not enough to cause a problem i darent say as its designed to average about 35mph over 4hours at Goodwood.
The reason I ask you all about the shape in the first place is that being so far away from the car and having very limited testing pre bodywork, I'm desperately trying to work out how I can expect it to place on sunday all being well.
Posted: 23 Apr 2009, 13:18
by johnny99
There seems to be a large enough radius at the front, which may give a bit of drag, if that was to replaced with a sharper edge, it may lower the drag at the front.
John
Posted: 23 Apr 2009, 19:05
the nose is quite rounded, yes, but the thinking behind that (after years of cars with square edges in that place) was that rather than force air a particular way let it choose its own natural path a little easier or does that all just sound a bit "new age"?? The tail does turn upwards the same amount at the rear to equalise pressure.
Here's another slightly more together picture..
... I know still no tail on there
Posted: 23 Apr 2009, 19:43
by Jersey Tom
greenpower dude reloaded wrote:I think when I worked it out it was within the general 15/16deg(depending on who you ask) rule which states anything greater than that will cause turbulence.
I thought that was in regard to venturi's and a 15/16 degree included angle, which would be 7-8 degree in your case.
I could be wrong. Plus I'm not sure what the Reynolds # would be in this case.
Posted: 23 Apr 2009, 20:34
by Gecko
johnny99 wrote:There seems to be a large enough radius at the front, which may give a bit of drag, if that was to replaced with a sharper edge, it may lower the drag at the front.
The skin friction drag due to accelerating the air over a more curved surface near the front is really negligible in the current design.
The biggest sort of drag you can expect from the shape as shown is the vortices generated from the air spilling detaching at the sharp angle at the sides near the front, and similarly at the back. It might be worth taping some threads on the car and see where the flow detaches.
For this reason, it might be worth extending the side panels near the front and the rear a bit in order to create fences to better direct the air over the car, but again, just how far to go with that isn't easy to figure out.
Posted: 23 Apr 2009, 22:45
to give you a bit more of an idea, this was last years car. we had a bit more time then to make a fibreglass body but clearly not enough to do it all.
As you can see underneath was really rough and there were bits sticking out of the car everywhere. The ground clearance was also much lower, about 30mm but it would seem a low ground clearance isn't always the best course of action.
anything 15mm and under is brilliant as it stops air going underneath unfortunately rules do not allow this. The minimum is now 40mm so it's better to raise it off the deck a little bit and allow it to flow through. I suspect that there was a huge amount of interference drag under the previous vehicle... What do you think??
