Amount and distribution of downforce in a 2003 F1 car
Posted: 13 Sep 2009, 23:48
Hello,
I am trying to do a simulation of 2 cars of the F1 2003 season (Ferrari and Renault) using the game rFactor.
Currently I am trying to simulate the aerodynamics, and I have found the following information:
About drag, the drag coefficient is between 0.7 (Monza) and 1.1 (Monaco). That seems to be quite clear. The problem comes with the distribution of the drag in the different parts of the car:
I have found this distribution:
Front wing: 10%
Rear wing: 35%
Underside of the car: 15%
Rest of the car: 40%
Then I looked at values of the F2002 car from the game F1 Challenge, which is the car that I am using as reference (I just thought that if the game was licensed, the physical values shouldbe realistic), and the distribution is the following:
Front wing: 20 - 25%
Rear wing: 10 - 40%
Bodywork: 40 - 65%
So I am confused and I don't know what values I should use.
The same problem comes with the downforce, because I have found very different information.
35 - 40%: rear wing
25 - 30%: front wing
20 - 25%: diffuser
5 - 10%: body work
But I've also found that one:
Front wing: 30%
Rear wing: 30%
Underside of the car: 55%
Then I looked at values of the F2002 car from the game F1 Challenge, and the distribution is the following:
Front wing: 17 - 28%
Rear wing: 14 - 32%
Diffuser: 40 - 68%
And also there's different values of the amount of downforce.
I have found that at 240 km/h, the car has got 1200 kg of downforce at Monaco and 1000 kg of downforce at Monza. In another website I have found that at the same speed, the car has got around 1900 kg of downforce. And the values of the amount of downforce from the F2002 from F1 Challenge are 770 kg at Monza and 1300 kg at Monaco (at 240 km/h).
So I decided to ask here to find the correct values. What I need is the distribution of drag and downforce in the different parts of the car (it would be great to know if the distribution changes depending of the track) and the amount of drag and downforce that the car generates (and at which speed) at Monza and at Monaco. Everything should be from the year 2003, and it doesn't need to be exact, an approximation can be useful too.
Thanks in advance,
GGSF1
Front wing: 10%
Rear wing: 35%
Rear wing: 10 - 40%
Bodywork: 40 - 65%
35 - 40%: rear wing
20 - 25%: diffuser
5 - 10%: body work
Front wing: 30%
Rear wing: 30%
Rear wing: 14 - 32%
Diffuser: 40 - 68%
Thanks in advance,
GGSF1
