Page 1 of 2
when u turn ur engine off whats that clicking sound?
Posted: 16 Jan 2010, 13:14
by adam2007
u know when u turn ur engine off car, sometimes after 5mins u hear that clicking noise whats that? i heard maybe a EGR valve but not sure any idears? i have heard it on loads of random cars in carparks when walking past
Re: when u turn ur engine off whats that clicking sound?
Posted: 16 Jan 2010, 13:21
by xpensive
adam2007 wrote:u know when u turn ur engine off car, sometimes after 5mins u hear that clicking noise whats that? i heard maybe a EGR valve but not sure any idears? i have heard it on loads of random cars in carparks when walking past
If you drive a Koenigsegg, like I do, that's the typical sound after the aluminium engine-block has adapted its
thermal expansion to the carbon fibre body, when the anti-torque pins lock into place.
Posted: 16 Jan 2010, 13:32
by tarzoon
can you explain this a bit better?
Posted: 16 Jan 2010, 13:42
by CMSMJ1
the engine "ticks" as it cools down. Just the metal relaxing after a good session.
My Koennigsegg does't tick as much as my Bugatti Royale...
Posted: 16 Jan 2010, 14:02
by xpensive
Christian von Koenigsegg built me a special edition, called
CCX^2, don't know xactly what he meant by "squared" though.
Posted: 16 Jan 2010, 14:53
by tarzoon
koenigsegg^2 =
1 engine
4 seats
16 wheels
1 steering wheel
4 pedals
1 handbrake
4 deca-whatever-dral doors
9 mirrors (1 internal, 4 external) - sorry about my maths here, still trying to understand it
and it goes on
Posted: 16 Jan 2010, 15:12
by Pandamasque
That's even more annoying if you have a time machine like I do. I ticks all the bloody time.
Posted: 16 Jan 2010, 15:43
by donskar
If this sound is NOT the heated metal cooling (it probably is), then it could be the fuel system releasing pressure.
Posted: 16 Jan 2010, 15:56
by Giblet
In some cars you hear oil dripping onto the shallow part of the oil pan as well, which is a louder rhythmic clicking.
by xpensive
tarzoon wrote:koenigsegg^2 =
1 engine
4 seats
16 wheels
1 steering wheel
4 pedals
1 handbrake
and it goes on
I don't know, perhaps Christian was referring to the driver?
Posted: 16 Jan 2010, 23:17
by alexbarwell
If its got 16 wheels, we might have seen it on Thunderbirds.
The ticking on mine is usually the exhaust cooling down, there are a couple of valves that motor shut after a while, but the constant pink-pink noise is the exhaust - when hot the original used to just tap on the rear valance...
Posted: 17 Jan 2010, 02:19
by Giblet
Mine lets out a sigh of exasperation and asks me not to drive anymore.
Posted: 17 Jan 2010, 02:22
by alexbarwell
Or its the sound of all the loose bits of metal falling back into the sump...
Posted: 17 Jan 2010, 02:43
by Giblet
My loose 'bit of metal' was the valve head, that had broke off when the timing belt snapped loose, as the piston crashed into the open valves.
I never found the valve head, but the hole in the side of the block, and the top of the piston looking as beaten as an anvil was a clue as to what had happened.
I love Honda engines, bit those timing belts are whores if you don't change them regularly.
Posted: 22 Jan 2010, 16:38
by ISLAMATRON
The've switched to timing chains now havent they?
