Page 1 of 2
why cant you see the airflow?
Posted: 28 Feb 2010, 23:59
by adam2007
why cant you see the air flow over the wings when the car is doing like 160mph? if you get what i mean?
like all the "white" air going over the wing showing the vortex's and etc
Re: why cant you see the airflow?
Posted: 01 Mar 2010, 00:22
by wesley123
because air dont got any colour?
If air got an colour we couldnt see anything
Posted: 01 Mar 2010, 00:26
by tomislavp4
Yup, air is invisible man, it doesn't matter if you are moving through it with 5mph or 500mph, it will remain invisible :wink:
Posted: 01 Mar 2010, 00:29
by horse
adam2007 wrote:why cant you see the air flow over the wings when the car is doing like 160mph? if you get what i mean?
The tip vortices are always there, you just do not see them all the time as the humidity and speeds are not high enough. The white stuff is basically clouds forming about the vortex cores and their appearance is governed by a complicated interaction between the temperature/pressure change caused by the vortices and the humidity/dew point of the air.
You can try and follow this wikipedia article Wingtip vortices
Posted: 01 Mar 2010, 00:58
by Scotracer
The only thing you see is the condensed water in low-pressure areas, such as the wing-tip vortices.
Posted: 01 Mar 2010, 01:06
by PNSD
Though the previous posts are 100% correct, along with the use of flow-vis we do sometimes get these rare moments where we can see airflow ;-)!
Posted: 01 Mar 2010, 01:46
by Just_a_fan
Sometimes you can. It just needs the correct atmospheric conditions. We saw it last year in the wet races just before it rained. At least some rear wing tip vortices were visible; don't remember seeing any under wing flow condensing though.
Posted: 01 Mar 2010, 04:36
by Giblet
I've posted this image before.
It's all just fluid.
Posted: 01 Mar 2010, 09:45
by adam2007
how do they show the air in wind tunnel then? they spray it on the wing you can see it sepeate over the wing? i saw some airflow of rear wing ages ago just strands of air
Posted: 01 Mar 2010, 09:55
by raymondu999
What they do if I'm not wrong is use some smoke (or something white I'm not sure what it's called lol) in the air in front of the car. That way as the grey airflow (colored by the smoke goes through the car with the air, it's possible to see the airflow.
Posted: 01 Mar 2010, 23:18
by kalinka
It is indeed visible in right conditions :
http://www.f1today.nl/fotos/p305lco66.jpg
You can see a few examples on above page.
High hunidity/high speed i think.
Posted: 01 Mar 2010, 23:31
by Lurk
I remember that at the end of the 90's, vortex were clearly visible on rear wings... (as in kalinka's link)
Giblet wrote:It's all just fluid.
But water density is not the same as air density, so flow is not the same :wink:
Posted: 01 Mar 2010, 23:37
by Giblet
Don't worry, my tongue must not have been entirely in me cheek there.
In that pic, the car was going very slowly, so the visual effect at that speed might have been similar looking to what the air would like like at very high speed.
Posted: 02 Mar 2010, 00:01
by Lurk
Well... My native langage is not english so I'm not sure of the signification of your first sentence...
No problem with your second one :wink:
ps: is canadian flag for hockey final? Anyway it was a great match!
Posted: 02 Mar 2010, 00:05
by Giblet
Sorry Lurk, I just mean that I was being sarcastic about the fluid. I thought the question was odd that someone was surprised they couldn't see air.
Oh yes, the flag is for the hockey final, but also just in bragging recognition about our new Olympic record, and how well the Olympics went.
The luge accident not withstanding, but that was for the most part unpredictable, although very sad.
