Page 1 of 3
How much is a "point" of downforce?
Posted: 29 Mar 2010, 18:37
by raymondu999
I've often heard of downforce quantified in "points." I saw in one of the videos on YouTube of turning the mp4-24 into a race winner that they added "30 points." How much is a point of downforce? For example, in terms of downforce, at x speed, how much more downforce does an extra point of downforce generate?
Re: How much is a "point" of downforce?
Posted: 29 Mar 2010, 18:41
by Giblet
raymondu999 wrote:I've often heard of downforce quantified in "points." I saw in one of the videos on YouTube of turning the mp4-24 into a race winner that they added "30 points." How much is a point of downforce? For example, in terms of downforce, at x speed, how much more downforce does an extra point of downforce generate?
A point is the same as a click. It's an arbitrary number for us, but a real number to the team. They know what one click is, but you can just think of it as one 'step'.
A click on a Reanault wing is not the same as a point on a Ferrari wing.
They sometimes call it a turn, or half turn of downforce as it's done with a ratchet.
Posted: 29 Mar 2010, 18:45
by raymondu999
AH. So it's actually just an internal convention on how to quantify it?
Posted: 29 Mar 2010, 23:39
by shelly
As far as I know in most of the teams 1 point corresponds to 0.000048*(speed in kph)^2 kg of downforce.
i.e @ 250kph 1 point is roughly 3kg of downforce; @ 300 kph 1 point is 4.3kg of downforce
Posted: 30 Mar 2010, 01:10
by Jersey Tom
shelly wrote:As far as I know in most of the teams 1 point corresponds to 0.000048*(speed in kph)^2 kg of downforce.
Where did you come across this?
Posted: 30 Mar 2010, 08:42
by Richard
I'm intrigued by the 0.000048. It looks like one of those magic constants that has a simple neat origin.
Posted: 30 Mar 2010, 09:27
by twoshots
Always one of those little things that I wondered about. Not being an aero guy myself.
In fact it cropped up at the weekend with Whitmarsh's comments that Hamilton losing his front wing end plate cost 10 points of downforce. 10 'sounds' like a lot, but without a way to quantify it with units...
Posted: 31 Mar 2010, 01:09
by newbie
a point of downforce is the same throughout the F1 teams from what I understand. downforce is measured not in Cl (lift coefficient) but in a similar parameter with a similar magnitude. A point is worth 0.01 of this parameter and a unit is worth 0.001. so for example if a hypothetical F1 DID use Cl to quantify downforce and their F1 car has a Cl of 4.000, then adding 30 points of downforce would bring the car up to a Cl of 4.300.
Posted: 31 Mar 2010, 01:47
by Jersey Tom
Honestly sounds like BS to me. An arbitrary measure. Could be whatever units you want. Pounds, kilos, some dimensionless measure...
Posted: 31 Mar 2010, 04:46
by Mystery Steve
newbie wrote:a point of downforce is the same throughout the F1 teams from what I understand. downforce is measured not in Cl (lift coefficient) but in a similar parameter with a similar magnitude. A point is worth 0.01 of this parameter and a unit is worth 0.001. so for example if a hypothetical F1 DID use Cl to quantify downforce and their F1 car has a Cl of 4.000, then adding 30 points of downforce would bring the car up to a Cl of 4.300.
I think this is common in general. Simon McBeath's columns in Racecar Engineering magazine use this convention, for example.
Posted: 01 Apr 2010, 01:10
by shelly
I agree with newbie and mistery steve.
Downforce=0.5*(air density)*(speed)^2*(reference area)*Cl
Usually you don't work with Cl, but with [reference area*Cl], namely SCl.
SCl has the dimension of surface, i.e. m^2 in SI; typical values are between 2 and 5.
1 point corresponds to SCl=0.01m^2:
if your car improves from SCl=4 to SCl=4.30 it has gained 30 points of downforce.
Working with points is easier because you work with numbers like 5, 7, 30 instead of 0.05, 0.07, 0.30.
If in the formula for downforce you substitute air density=1.22 kg/m^3 and take into account dividing by 3.6^2 (conversion for speed from m/s to kph) and by 9.81 (conversion from N to kg) you get
Downforce=0.0048*(speed in kph)^2*SCl
and finally with 1 point corresponding to SCl=0.01m^2
1 point [kg] = 0.000048*(speed [kph])^2
Posted: 02 Apr 2010, 01:21
by newbie
shelly hit the nail on the head. using SCL rather than CL is advantageous because you dont need to continuously keep track of frontal area.
Posted: 02 Apr 2010, 01:40
by autogyro
Well I think it is just a way to avoid placing an understandable measure on it that others would relate to.
This is to make it difficult for the FIA to define a set maximum for regulation.
An old saying of mine. Bulls--- baffles brains covers it.
Posted: 02 Apr 2010, 07:39
by Pierce89
autogyro wrote:Well I think it is just a way to avoid placing an understandable measure on it that others would relate to.
If that's the case, why would Mcbeath in Racecar Engineering use points of DF as a reference in articles about modifying 30 year old racecars
Posted: 02 Apr 2010, 13:17
by autogyro
You tell me?
