How About Wake Modification?
Posted: 17 Apr 2010, 22:36
Having just joined this forum, I apologize if the following is old hat here.
Even on aircraft, stall only increases drag, and it’s induced by increased angle of attack. On an F1 car the rear wing's angle of attack is constant, so it can only be stalled by “spoiling” the flow over it. This can be done, for instance, by placing a small span-wise slot in the low static pressure area near the airfoil’s leading edge and feeding small amounts of air into that region. The effect would be boundary layer separation at that point, producing the equivalent of stall.
But why ever reduce down force at the expense of drag? I suspect there is something else at play here. How about wake flow modification? Stalling the wing at high speed would certainly do that. It would convert the trailing edge of the upper foil into a vertical knife edge producing a different turbulence pattern behind. What if something like a Kamm effect could produce a wake pattern that nets less drag? To really know, one would have to observe this with smoke trails in a wind tunnel. Somebody might have stumbled across this by increasing the angle of attack of the upper foil excessively.
Those drafting an F1 car know that there is a lot of energy in its wake, and it all comes from the car that produces the wake. In a macro sense, reducing that wake energy benefits the car. Wake flow behind an F1 car is hard to treat analytically, given the multiple influence factors affecting it. Long live the wind tunnel, not withstanding CFD.
