Page 1 of 1
front wing adjustment
Posted: 10 May 2010, 11:42
by roger44
I noticed Webber adjusting his front wing using a thumbwheel encoder on his seering wheel. I always thought the driver could only make it go up or down.
Does anyone know if the driver can set the front wing to otehr angles during the race?
Re: front wing adjustment
Posted: 10 May 2010, 13:41
by raceman
roger44 wrote:I noticed Webber adjusting his front wing using a thumbwheel encoder on his seering wheel. I always thought the driver could only make it go up or down.
No. The front wing can be adjusted by driver only two times during a lap for 6 degrees max. There is no other way a driver can adjust the front wing from his cockpit - he has to pit for it.
Posted: 10 May 2010, 13:55
by roger44
yes, but can he make a small adjustment, ie to allow for decreasing fuel load
Posted: 10 May 2010, 14:22
by raceman
The only adjustment a driver can made from the cockpit is the allowed 6-degree move of front wing flap; nothing else with the front wing. The pit crew can make changes to the angle of attack during a pit stop - you must have seen this.
Posted: 10 May 2010, 14:25
by roger44
thanks Raceman, I wasnt sure, cos Webber seemed to be making a lot of changes to his wing. Its not often you notice them using the thumbwheel so I guess it looked more noticeable than normal.
