F1 In Schools help : Pudin's project
flynfrog
Re: F1 In Schools help : Pudin's project
thats looking better but remember leading edges should be round not points. Also if you can learn how to sweep you could blend the front of the co2 chamber really well. Next question do you have a way to test your designs?
pudin
We test by using our phoenics vwt software,but the software's files corrupted,so we can only manufac the car and blast off.
:D
You got any ideas?
I love my mom
flynfrog
if you can build them easy enough race them. The problem is the many variables involved in car construction. Maybe figure out your average speed and build a wind tunnel.I am thinking a glass plate a leave blower and some sort of scale. Could be a spring and a marker.
pudin
It's heard to find leaf blower these days,maybe a vacuum cleaner can help,but not enough power to blow the water into sprinkles.
Maybe a fan?
And what exactly that we want to see in the wind tunnel?
Of course the wind direction,but what kind of wind movement that we want to see?
The wind flow continuity?
The thing that i learnt from previous post is that the faster the air movement the higher the drag,that explain the venturi effect.
And if the air combine(something like that) back with the air flow,that too will increase drag.
Do this things that we must observe in this WT?
I love my mom
pudin
My 1st car actually did around 1.05 sec at the start of this thread.
Im eager to test this car at the track.
This car's aero is better right than before?
So,im hoping this car will do around 1.04.
Do u have any VWT software to test this car?
If you have maybe i can email you car to analyze it.
Maybe a Turbine Engineer like you have a better software perhaps?
:wink:
I love my mom
flynfrog
The software you are looking for is called CFD software unfortunately I cant use my software at work for personal use. In the wind tunnel you would place the car on a flat pad with the fan going you would measure how far back it is pushed against the spring. This would be a rough and ugly way to measure drag comparatively between cars.
http://www.grc.nasa.gov/WWW/K-12/airplane/forces.html
think of your car as a jet without minimal lift.
Diy wind tunnels. Maybe get an Rc plane prop and a motor?
http://www.theplanpage.com/Months/2306/ ... tunnel.pdf
http://www.rcgroups.com/forums/showthread.php?t=626474
pudin
You're right,it does seem ugly and unaccurate.
I've gotten my CFD software,but it takes time to configure it.
Maybe constructing a WT is a good idea that i can add to my 20 pages portfolio.
Should i try the other car or just this car?
I love my mom
pudin
BTW,i wonder,if i construct a water wind tunnel could it be better result?
I love my mom
pudin
An one more thing,if i hollow my sidepods just to reduce the mass,could it increase drag?
Because when there's vacuum,there's drag
I love my mom
Izzy410
CFD software, the pheonics thing, it isnt corrupted. just make a new user on the windows OS. and you should be able to use VWT. i've had the error once.
hope that helps
-Team Adroit-
Technical Engineer
Team Adroit
SMK Aminuddin Baki
We're Just Fast
Question is, Are YOU?
flynfrog
you could do a water wind tunnel as well keep in mind that with water your speeds will not correlate directly to air and any type of measurement you do now has to be water proof. Instead of hollowing them maybe try to shape them lower in the center but still gently curving up to meet the wheels.
I cant tell you when to stop building cars. I can tell you your current car has a long way to go from being optimized. But without any means to quantify data you will be taking shots in the dark.
flynfrog
Image maybe something like this
pudin
Is this okay?
Or maybe curve more?
But,i wonder,isn't it producing vacuum?
Or it isn't :?:
I love my mom
flynfrog
you could do both the top and bottom. don't you need a certain area to be there for a side pod.
It could be adding drag but you have no way of knowing how much without testing. It could be the weight penalty is worth the drag may not be. This is where engineers earn there money.
flynfrog
one other not try to keep the basic shape of every thing sticking out wing like
round on the front edge sharp edge on the back. This allows the air a chance to stick to the surface at the front and get a clean break at the rear.
http://en.wikipedia.org/wiki/Drag_coefficient
Post Reply
