Ringo F1 design
225
Re: Ringo F1 design
Wait a minute!! the front wing tunnel....
Tozza Mazza
Re: Ringo F1 design
pssst, Ringo.
The E20 fw is the same as the one on the R31, and there is no tunnel on the endplate...
pascaljackson
Re: Ringo F1 design
moreover such a tunnel is nothing new ;)
jordangp
Contact:
Re: Ringo F1 design
yeah, it's the same wing as end of last season. It's been a long time since I've seen you around pascal. I think your car had something similar didnt it?
225
Re: Ringo F1 design
Yeah i realized.
the tunnel on my wing is different however. it doesnt put air under the end plate. It pushes it out around the outside of the wheel.
Non existent in F1, and it seems probably not necessary as no team has used it.
bhall
244
Re: Ringo F1 design
Could you have a tunnel from the tea tray, underneath the cockpit and so on, that exits at the rear? (Seems like as good of a place as any to ask.)
MIKEY_!
Re: Ringo F1 design
Would function a bit like the STR sidepods from last year. It could work but getting enough air volume through the system would be a challenge without compromising other parts of the car.
MarkedOne8
Re: Ringo F1 design
Which software is used for this design?
And one more question.How to do test of aerodynamic efficiency?
Fernando Alonso is the best pay-to-drive driver in F1 with the biggest amount of money behind him.
http://f1bias.com/2012/04/05/truth-abou ... nder-2008/
225
Re: Ringo F1 design
this is solid works. For aero efficiency i guess you find the Lift/ drag of the car.
When i test; which is really just my little amateur testing. I do the whole car, but i only draw results from say the rear wing, then the front wing, then the body, then the floor; to isolate the parts and see how well they do and what they contribute.
Ofcourse some times i do the whole car and get the L/D or the center of pressure.
I need to get back on this, this weekend. Keep making promises i cant keep with the car. Gonna change it to 2012. Nose will be interesting design. 8)
bhall
244
Re: Ringo F1 design
I have the strangest feeling that someone around here is responsible for this.
allstaruk08
Re: Ringo F1 design
hahahaha
Ferrari_Ivan
Re: Ringo F1 design
very beautiful and brilliant ideas! Your design is very interesting.
are you use SolidWorks?
are there hidden innovative aerodynamic points?
MemroableC
Re: Ringo F1 design
Ringo if you get a chance could you upload the car, as a fellow solidworks user i would love to see the technique used to model the car and maybe run some cfd on it for fun.
dumtisdumtis
Contact:
Re: Ringo F1 design
Good surfacing skills...
Have you considered continuity of the surfaces while modelling the car? Do you have information on which continuity type is being used in F1, or does it matter on aerodynamic performance of the car?
Tozza Mazza
Re: Ringo F1 design
Ferrari_Ivan wrote:are there hidden innovative aerodynamic points?
Oh god...
Post Reply
