2024 Scuderia Ferrari F1 Team
Space-heat
Space-heat
Zynerji wrote:
03 May 2024, 19:15
Vanja #66 wrote:
03 May 2024, 19:12
Xyz22 wrote:
03 May 2024, 19:05
He was already lucky to not destroy the car.
Yeah, so lucky, overheating clutch after 3 laps is not at all a potential gearbox issue
I think its more likely a driver error... :lol:
Are we not assuming the clutch overheated while Charles was not moving trying to spin the car.
Annoyingly it seems like Lewis was happy to wait for Charles to turn but he missed the opportunity. I hope he wasn't trying to save the tires with his failed mini spin. At least Carlos looks strong...
CouncilorIrissa
CouncilorIrissa
Very small gains coming from hards to softs in S1.
edit: better S1 on his second attempt. As usual :lol:
Zynerji
109
Space-heat wrote:
03 May 2024, 19:23
Zynerji wrote:
03 May 2024, 19:15
Vanja #66 wrote:
03 May 2024, 19:12
Well. The clutch has a paddle on the wheel that the driver is 100% in control. Barring an actual mechanical failure, the most likely cause of overheating is the driver slipping and slamming the clutch, on purpose.
Space-heat
Space-heat
CouncilorIrissa wrote:
03 May 2024, 19:24
They did a front wing adjust after the first push lap. Might have helped.
Xyz22
Xyz22
97
Seems a very easy WE for RB.
Max was P1 with an awful third sector.
dia6olo
dia6olo
I have a sneaky feeling these high track temperatures are going to work really well for Ferrari both in Quali but the race in particular...
dia6olo wrote:
03 May 2024, 19:54
No doubt. They have the worst warmup and best deg of the top teams. High track temps means naturally it is better for them
dialtone
dialtone
112
dia6olo wrote:
03 May 2024, 19:54
We'll see, sprint quali will be +1C ambient and cloud cover is going away so it's going to be very toasty.
Waz
Waz
Vanja #66 wrote:
03 May 2024, 19:12
Xyz22 wrote:
03 May 2024, 19:05
That whole spin seemed very strange. Almost like the ERS just dumped full power on him without warning.
codetower
Waz wrote:
03 May 2024, 21:36
Vanja #66 wrote:
03 May 2024, 19:12
Xyz22 wrote:
03 May 2024, 19:05
could have been a gust of wind, or just the wrong setup and the car lost traction after coming off the kerb. It did look odd, though. He wasn't going THAT fast there. Lots of drivers were having early issues today including ALO and VER.
How much setup can they do DURING the sprint qualifying? Or are they locked in once the car hits the track in SQ1?
dialtone
dialtone
112
codetower wrote:
03 May 2024, 21:43
Waz wrote:
03 May 2024, 21:36
Vanja #66 wrote:
03 May 2024, 19:12
Even if they weren't locked, there's not enough time to change suspension settings and such. They can always tweak wings though.
CouncilorIrissa
CouncilorIrissa
Even at 48 C they need 2 laps to get the tyres up to temp.
murphy
murphy
Re: Ferrari SF-24
f1316 wrote:
03 May 2024, 16:15
murphy wrote:
03 May 2024, 15:52
I think Ferrari will go for the overbite, to me its common sense, it allows much more air in and then around the car to to the back, if you look at the sidepod inlet on the current car the whole front part is just a panel you can screw it off and put something else on, the upgrade in Miami could setting the up. Got to say i love what they have done with the halo, where it curves down is pretty much flat.
Ultimately it doesn’t matter - they’ll go for whatever got them the best results in the tunnel. So long as there’s correlation in real life, it doesn’t matter if it’s an underbite or overbite or whatever - what matters is how big of a step the overall package is. We know it’s supposed to be significant - I’m sceptical about believing laptime numbers bandied around - but even if we believe it’s the 2-3 tenths suggested, that’ll make a big difference (especially in quali which will enable better race strategies as well as overall stronger race pace).
Of course it doesn't matter whatever the whole package will be, all i care about is the car having more pace, thats just my humble opinion. Correlation is arguably the most important thing, its why Merc are such a mess.
CouncilorIrissa
CouncilorIrissa
Leclerc is clearly washed. /s
But we're lucky that Norris is garbage in qualifying.
IntrinsicVoid
IntrinsicVoid
Zynerji wrote:
03 May 2024, 19:00
Vanja #66 wrote:
03 May 2024, 18:58
Overheated clutch, no reverse after spin. How do these things happen only on Leclerc's side of the garage?
Because its super obvious that Ferrari kept the wrong driver. :roll:
