Mercedes W14
Re: Mercedes W14
18 Feb 2023, 01:07
Cockpit distance looks the same to me. It's has been a Mercedes trait to use the maximum allowed length ofr front wheel to cockpit though... So I supposed they did that in 2022 and 2023..
Their 2022 cockpit was already far forward, much further than Ferrari & obviously RB
With their fuel tank shape, it's not easy to have a backward cockpit...
Re: Mercedes W14
Andi76 wrote:
18 Feb 2023, 19:56
OO7 wrote:
18 Feb 2023, 19:05
Andi76 wrote:
18 Feb 2023, 18:20
This is ideal. Its about 15 cm more to the front. It was said that too much rearward weight distribution also in relation to the CoP was the big problem of the W13.
https://postimg.cc/D82CVjyD
The weight distro is pretty much fixed by regulation.
You say it - pretty much. But not fixed. There is still a window of 12 kgs to play with. 12 kg too much at the front or rear can definitely make a difference in race cars, especially in connection with the CoP. I have seen many comparisons and in my opinion they definetely changed the weight distribution by transferring the driver position to the front.
Where are you seeing a 12kg tolerance?
Andi76
Andi76
405
Re: Mercedes W14
Blackout wrote:
18 Feb 2023, 20:05
18 Feb 2023, 01:07
https://i.imgur.com/Te6CGOb.gif
I don't think this comparison is accurate. Its a well known fact and was widely reported that Mercedes had the most rearward driver position in 2022. I would have to be very wrong about that now.
Andi76
Andi76
405
Re: Mercedes W14
18 Feb 2023, 20:17
Andi76 wrote:
18 Feb 2023, 19:56
OO7 wrote:
18 Feb 2023, 19:05
https://i.postimg.cc/J7KdBJzz/image.png
0.445+0.540=0.985 so they have 1,5% to play with. Or 796×0.445=354.23, 796x0.540=429.84 ---> 354.23+429.84=784.06 so almost 12 kg to play with. So contrary to what obviously many believe, there is very much a margin.
chrisc90
38
Re: Mercedes W14
free image hosting
internal floor stays? Brightness raised on this post
Re: Mercedes W14
Andi76 wrote:
18 Feb 2023, 20:28
Blackout wrote:
18 Feb 2023, 20:05
18 Feb 2023, 01:07
I don't think this comparison is accurate. It a well known fact that Mercedes had the most rearward driver position in 2022.
The comparison is very accurate for a human being (look at the wheels). The pics were taken by the same photographer in the same place and in a short amount of time. And obviously the camera angle is near perfect and 100 times bette than the pics you re using.
+ with the fuel tank shape Mercedes has, you cannot technically place the cockpit far rearwards like RB or MCL, unless you add 50cm to the car's length or width.
RB & MCL clearly had the most backward cockpit, while Mer and Alpine were one of the most forward
Stu
Re: Mercedes W14
Andi76 wrote:
18 Feb 2023, 20:32
18 Feb 2023, 20:17
Andi76 wrote:
18 Feb 2023, 19:56
The important part of the regulation is the variation is “at any time during the competition”, potentially that is the difference between a full fuel tank and one with the 1litre sample left in it; is the fuel tank at the CoG??
Andi76
Andi76
405
Re: Mercedes W14
Blackout wrote:
18 Feb 2023, 20:40
Andi76 wrote:
18 Feb 2023, 20:28
Blackout wrote:
18 Feb 2023, 20:05
The comparison is very accurate. The pics were taken by the same photographer in the same place and in a short amount of time. And obviously the camera angle is near perfect and 100 times bette than the pics you re using.
+ with the fuel tank shape Mercedes has, you cannot technically place the cockpit far rearwards, unless you add 50cm to the car's length or width.
This information is from F1s own website and Marc Hughes :
I checked this to make sure I wasn't mistaken, although I was sure because it was said so many times. The driver's position and sidepods were further back on the Mercedes than on Ferrari and Red Bull. The engine was moved further back especially for this. As I said - was explained 2022 umpteen times by all experts whether Hughes, Piola and how they are called all. And I believe that they know a little more precisely, after all, they are standing next to the cars.
jumpingfish
53
Re: Mercedes W14
Andi76 wrote:
18 Feb 2023, 20:52
Blackout wrote:
18 Feb 2023, 20:40
Andi76 wrote:
18 Feb 2023, 20:28
https://postimages.org/
I think that W13 render on the image is not what was on track during 2022 season
Andi76
Andi76
405
Re: Mercedes W14
Stu wrote:
18 Feb 2023, 20:50
Andi76 wrote:
18 Feb 2023, 20:32
18 Feb 2023, 20:17
It isn't. That's exactly the leeway the teams have in their weight distribution. I know this personally from engineers. That's the leeway that the teams were able to keep in this regard and that the FIA also wanted to give, because they also wanted some leeway.
Andi76
Andi76
405
Re: Mercedes W14
jumpingfish wrote:
18 Feb 2023, 20:56
Andi76 wrote:
18 Feb 2023, 20:52
Blackout wrote:
18 Feb 2023, 20:40
We can go around in circles here and keep saying -this photo has lens distortion or this render doesn't...the fact is that pretty much all the people who have seen the cars in person every week have said unanimously throughout the 2022 season that Mercedes had the cockpit set back the furthest. And they moved the engine back for that. That is simply the way it is. If someone does not want to believe that now, whether out of injured vanity because he posted something else here or because he believes other sources than these more - ok. But I am out of it now. Because more than the page of Formula 1 itself or Marc Hughes and people who have seen these cars weekly with their own cars - you can not cite as evidence. Because the actual car itself, unfortunately, I can not put on the table.
Re: Mercedes W14
Andi76 wrote:
18 Feb 2023, 20:32
18 Feb 2023, 20:17
Andi76 wrote:
18 Feb 2023, 19:56
Thanks for that, I glossed over the fact that this regulation does not add up to 1.
Re: Mercedes W14
Andi76 wrote:
18 Feb 2023, 20:52
Blackout wrote:
18 Feb 2023, 20:40
Andi76 wrote:
18 Feb 2023, 20:28
Not only it's Mark Hughes (who has very little credibility), you are also showing me that completely nonsenical comparison using the totally fake and wrong 3d render that Mercedes published in 2022... and this should be more accurate than my comparison? :lol:
The accurate photos and Technic speak for themselves and are indeed more credible than Mark Hughes, even if he sleeps with the car.
Re: Mercedes W14
@Andi76, we definitely cannot overlook the fake renders.
chrisc90
38
Re: Mercedes W14
https://ibb.co/t2FP8DZ - Viewing full size makes it evident.
Not sure if that shows the stays a bit better? I did view it on my phone and can hardly tell, but on laptop it was clear.
