Efficient positioning of nose cams on Honda
One peculiar thing on the new RA108 is without a doubt the mounting points of the camera hubs. Various teams have experimented with their position but Honda added a thick connection aerofoil to reduce the aerodynamic impact close to the nose cone. Other than that, the new concept of Honda shows with a completely redesigned front suspension. The thick root of the frontal upper wishbone effectively shortens the movable part of the arm. Also note that a horizontal splitter was added in between the upper and lower suspension elements, similar to items seen at McLaren and BMW Sauber.
Hi Tomba,
probably should be noted that those camera mountings appeared on the new Williams before the Honda.
