Zero keel or a twin keel after all?
Realising that all teams are now competing this season with a zero keel front suspension, I spotted this at the Belgian Grand Prix. The picture shows how the front suspension - which is totally different than that of the TF107 - is attached to the monocoque. The zero keel - which denotes the lack of vertical suspension support under the nose - allows for a much better airflow under the nose and towards the sidepods. The picture does show an extension on the car's centre line, but that is merely a manner of putting ballast in the right place.
So far for the zero keel then, because a closer look to the tub shows that the lower foremost wishbones are connecting to small extensions. One could therefore argue if this concerns an actual zero keel or a twin keel. The attachment of the turning vanes to the mini-keels does however reflect McLaren's 2003 design which has been adopted by most of today's competitors.
While those white brakelines (?) did trick my eye at first, I wouldn't consider those stubs pronounced enough to call this a twin keel.
