Ferrari continue outboard mirrors on F60
Despite the stringent regulations that specify just where bodywork is allowed, Ferrari have still found a way to mount its outboard wing mirrors. The new solution looks like a combination of the sidepod panel on the Red Bull RB4 with an added mirror. Renault previously tried to put its mirrors on the sidepod panels back on 2007 but reverted from the solution because of vibrations.
The Ferrari design clearly shows that the sidepod panel has two aligned parts from fairly thick carbon fibre to make sure that the mirrors are firmly held in place. No doubt the mounting positions of the panels - the rear one fixed to the sidepod, the front one to a floor extension - will add to that. As marked in the image, you lower (black) part of the panel is shaped in conjunction with the new smaller bargeboard to direct air around the sidepod.
The upper front of the sidepod itself is also shaped particularly. The most forward part hides the side impact crash structures. The rest of the sidepod bodywork pulls more to the back as it allows a cleaner airflow around the pod.
this is obviously against the "spirit" of the current regulations. i wonder if any other car will have a similar system or it will be another only-red-car technology. they may as well design a mirror which acts like a wing.
