F1 Quiz Chain
Post Wed Aug 08, 2012 7:39 am
Geoff Ferris and March 711 springs to my mind ...
marcush.
Post Wed Aug 08, 2012 10:36 am
- Max Sardou
- Renault RS01
- turbocharging and radial tyres
Seems a good idea to read books from time to time :)
matt21
Post Wed Aug 08, 2012 6:14 pm
http://www.sardou.net/index.html
Well done again matt21. Which book if I may ask ?
Sombrero
Post Wed Aug 08, 2012 8:34 pm
=D> =D> =D>
shame on me I well remember the Renault test hack...
marcush.
Post Thu Aug 09, 2012 8:39 am
I don't know when this should have happened or even who Max Sardou is, but Tony Rudd and Peter Wright worked on the concept at BRM already in the late sixties.
http://en.wikipedia.org/wiki/Ground_effect_in_cars
xpensive
Post Thu Aug 09, 2012 9:00 am
March: The Rise and Fall of a Motor Racing Legend by Mike Lawrence.
There was Max Sardou mentioned.
By the way does anybody know a post about f1 related books in this forum?
I want to increase my libary.
Next question:
What happend during a test at Snetterton with the Lotus 78 when fitted with the queerbox?
matt21
Post Thu Aug 09, 2012 8:44 pm
as far as i know the chief designer of RS01 was Andre de cortanze and also Jeanpierre Jaboille their driver was part of the design team ,a very unique situation ..having the cars designer actually drive the car in F1..and being competitive.
Yes Mclaren ,Brabham ,Purley Amon build their own cars yes but did they also pen it ? the one exception may have been John Surtees?
marcush.
Post Thu Aug 09, 2012 10:05 pm
You mean the day the Lotus crew tested the first launch control system without a pilot on-board ?
Insisting on a sequential shift box, Colin Chapman directed Tony Rudd and Brian Spooner to revive the “queerbox” as it was known when first used in the late 1950s on the Lotus 15 sports racer, as well as the Type 16 formula car. It was a tiny gearbox concept that, in theory at least, did not require use of the clutch to shift gears. It appeared briefly on the T78, that gave the drivers such a severe case of Tennis elbow - due to vibrations fed back through the lever during attempted shifts - that it was abandoned so as not to compromise the new car.
Chapman tested allready something similar with the T76. The clutch pedal was retained, but only used for starting. Thereafter, gearshifts were performed using a button on the gearlever to activate the clutch via an Electro-Hydraulic actuation system.
A final attempt was made with the Lotus T79. The Lotus/Getrag gearbox proved troublesome, and was replaced by mid-season with the more conventional Hewland FG400.
Sombrero
Post Fri Aug 10, 2012 7:22 am
Sombrero wrote:You mean the day the Lotus crew tested the first launch control system without a pilot on-board ?
Can you explain?
matt21
Post Fri Aug 10, 2012 6:17 pm
That day at Snetterton the gearbox selected a gear by itself while the engine was being warmed up. The car wandered off across the paddock, chased by the mechanics.
Sombrero
Post Mon Aug 13, 2012 7:27 am
Your turn! =D>
matt21
Post Mon Aug 13, 2012 9:54 am
There is a nice past quizz about the W12 of the Life F-1 Team posted by WhiteBlue
Now, if you cut that engine in 4 I mean W12 : 4 = W3 what is that ?
Yes, that W3 was built for F-1 purpose long ago.
Sombrero
Post Mon Aug 13, 2012 10:04 am
The designer of the W12, Franco Rocchi, built a 500cc-W3 in the 60´s for validation purpose.
matt21
Post Mon Aug 13, 2012 10:26 am
Man, that was so fast... Almost like Usain Bolt !
You are right : In 1967, Scuderia Ferrari engineer Franco Rocchi built an experimental 65×50mm, 498 cc W3 engine, effectively a single crankpin module, in order to assess the potential for a 3-litre W18 Formula 1 engine. Although the engine developed 80 bhp at 11,000 rpm and 160 bhp per litre, the idea was abandoned. Subsequently in 1972 Formula 1 rules were changed to outlaw the use of engines with more than 12 cylinders. Rocchi used this module as the basis for a 3½ litre W12 engine for Life Racing Engines in 1988, although this was infamously unsuccessful.
Here we can see a 1943 W18 Tatra T955 aircooled engine in its full glory.
Sombrero
Post Mon Aug 13, 2012 3:25 pm
What was for the last time when Schumacher had his first time win?
matt21
PreviousNext
Return to General chat
Who is online
Users browsing this forum: CCBot [Bot], raymondu999 and 8 guests
