Forza wrote:I've checked my database and it seems that file chn-session3-times.pdf is indeed corrupt so I don't have it either. I only have chn-session3-classification.pdf but this isn't useful for lap time analysis.
Thanks for checking that, Forza! If yours is corrupted too, then probably it will be almost impossible to find that file anywhere.
Forza wrote:
A bit of help with Fia site. You can search the file directory yourself. Only thing you need is file name and insert it into url aderess. Some PDFs are still stored on FIA page but they are relocated to different site folders.
And thanks for this explanation too.
I was aware of the 2008 files and the 2012 trick: the way the 2012 files are stored changed when they altered the layout of the Media Center.
Unfortunately China still used the old layout, so the trick doesn't work there.
IIRC, the filenames changed according to the race (race abbreviation in the filename) and the filenames wer moved once the presentation for the next race was made available.
However, I have been unable to find any of the 2009-2010-2011-2012 (first few races) after the files had been moved.
I have most of the files I need, it was just that it might have given me a clue about where they store it so I can get it if needed.
Forza wrote:
There are also some Fia PDF files available on
Speed F1 under
downloads section .
Unfortunately, even if the results on the webpage are from 2012 China, the PDF documents are those of the 2011 race.
Thank you for your efforts though, I appreciate
