I will start with a quote:
My translation:A differenza dell’attuale KERS – che da ai piloti una potenza extra di 80 cavalli per sei secondi al giro-, l’ERS del 2014 consentirà di avere attorno ai 160 cavalli in più per 33 secondi al giro. Per compensare la potenza extra generata in frenata dall’ERS, ai team sarà concesso di usare un sistema di controllo elettronico posteriore della frenata (electronic rear brake control system).
The second one comes from Peter Windsor discussing brake ducts in detail with Scarbs and the comments that maybe the rear brakes will be less powerful last year due to the ERS.Compared to the current KERS - which gives the drivers an extra power of 80 hp for six seconds - the ERS of 2014 will allow for a power output around 160 hp for 33 seconds a lap. To compensate for the extra breaking power generated by ERS the teams will be allowed to use an electronic rear brake control system.
Keep in mind that with the new regs I highly doubt that we will see kinetic energy of the drive shaft getting dumped into resistors and that the teams will likely try to harvest as much as possible for further use. It is pretty likely that the ERS braking will get used to the fullest extent possible. circumstances permitting. Let us now assume that the braking effect combined with standard rear brakes is powerful enough to safely exceed the braking power at the front, breaking balance in mind. Could the possible aero gain really be big enough to risk less powerful rear brakes?
BTW: The electronic rear brake control system brought up by James Key really sounds business which in turn could mean that at least some teams had some troubles to control the breaking at the rear by KERS.
The Racer's Edge, from around 15 minutes in.
P.S: A highly interesting and brilliant sign of things to come is the way RBR does adjust their front brakes to various far-away circuits. According to info gained by Scarbs they brought 2 3d-printers with them at each recent race and printed specific stuff, among the them the front brake ducts, right at the track in the pit garage! Cuts the time-to-market or race track by a considerable amount of time, giving the guys back at Milton Keynes more of that precious resources to fine tune various parts which now get dispatched digitally from home.
This has clearly also to do with the increased complexity of the design, for example Gurney flaps inside the duct and it's influence on tyre management.
Sorry, I meant to put that thread into the engine, transmission and controls forum. Maybe the dear mods could put it into the forum area in which it fits, according to them, best.
