Implement Ballast for F1
thevlack
thevlack
Would it work a "add ballast" per win in F1?
The system will work something like this:
For each victory, you get 2KG in ballast, the second consecutive victory give you an additional KG and the third just .5KG.
(You can change the values here, it was just to ilustrate).
Perhaps you can even after a couple of races with DNF or low scoring you can clear this.
I know that this may cause some teams/drivers to "avoid" winning (as they will have more weight to carry), but for us the outside people it will give us more interesting racing as some will have to overcome this handicap and win anyway and others may have an strategy.
So this may also contribute to the Cost Cap, as if you spend more, not necessarily you will take the crown at the end of the year.
Let me know what you think.
(Please move if its in the wrong place)
Roland Ehnström
Re: Implement Ballast for F1
No thanks.
JimClarkFan
JimClarkFan
27
lol.... =D>
''I approve this message
Regards
Bernie E''
Sebp
No more gimmicks please.
They did this in DTM a couple of years back. It was shyte.
No smartphone was involved in creating this message.
piast9
piast9
Yeah, nice idea. And the ballast should be in a form of a ball and chain attached to the rear crash structure just to make it visible (and audible) to the spectators which car has the ballast on it.
SectorOne
Also why not add shortcuts for Marussia and Caterham? And neon spraypainted horses glued to the actual tire itself while they are on the start grid.
And replace all horsepower with donkeypower. Oh and double points for the last race.
idfx
Sarcasm mode on -> Every victory the driver is bound to get fatter. The FIA ​​pays the barbecue. <- Sarcasm mode off.
Your idea would be interesting if you distribute to reward rather than punish teams.
Example: raffling a suite of performance for teams. This package let the faster car 1/2 sec. Only two teams have this package.
The special Set could have a lot of things:
Tires high resistance or speed, refueling, Set dowforce, etc. ..
