Found the teflon coating, it´s quite visible.
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
Unless their teflon spray has a dye in it? We use teflon sprays for sliding clamps and it is completely clear but it isn't unreasonable to assume theirs is dyed- why it would be dyed is another question unless it's just a simple case of just having whatever was on the shelf at the time.Thunders wrote:@SectorOne: I have to disagree with you on these Pictures.
It's just the combination of different Lighting and very different Picture Qualities.
I have tested a fair amount of high Quality Paint Sealants / Waxes over the Time and i would be absoultely shocked if one would change the Paint that much.
Maybe as an alternative for flo-vis?Gaz. wrote:Unless their teflon spray has a dye in it? We use teflon sprays for sliding clamps and it is completely clear but it isn't unreasonable to assume theirs is dyed- why it would be dyed is another question unless it's just a simple case of just having whatever was on the shelf at the time.Thunders wrote:@SectorOne: I have to disagree with you on these Pictures.
SectorOne wrote:Ok i´m not going to discuss what is blatantly obvious to see in the images.
Does it really matter what i say? The color is right in front of your own eyes.Thunders wrote:One Page before you mention Teflon would be a dark grey, now it would be blueish all of a sudden.....
SEE THIS STRANGE KIND OF PURPLE SPRAY ON IT?, well that is teflon spray, and that if they ever allow me to touch it which they wouldn´t, is very slippery. And they spray it on there to stop tire marbles from other cars getting lodged in the slot gap.
The effect you're talking about is thin film interference. It is caused by a thin film with a different index of refraction. The film itself does not even have to be transparent, for instance pure carbon can do it. However these kind of effects only take place with very thin films, typically in the order of 10's of nanometers. Like the oil membrane you see on a puddle. Not something you can achieve with a spray can and some rubbing. A teflon-like coating you would normally not see this way.turbof1 wrote:I'm not going to vouch for either of you, but I do have my own theory about it.
First off, have you ever seen gasoline in water in broad daylight? The mixture breaks the sunlight into its color spectrum. It's because the gasoline top reflects light differently then the water underneath.
I believe the purple is the same: the coating is colorless, but due the bottom paint reflecting light differently, and perhaps also the shadows from the garage play in it, the color spectrum splits and that is causing the purple hue. Obviously Tedt would be seeing this too.
It is known that teams use these coats, no question about it that Mercedes has one.
EDIT: I feel this doesn't belong here and is worthy enough for its own topic. I'll split it off later on.
