Getting serious in Bahrain
joseff
The last 2 pics also show the McLaren running the pitot tube on top of the rollbar camera housing. The answer to a question several posts ago.
Sawtooth-spike
Maybe Mclarren are so confidant they are fast that they plan to have a good view of all the cars behind them.
I think a few teams will follow this trend
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
i70q7m7ghw
i70q7m7ghw
49
Both sets are there more likely for the driver to choose on which he feels is best. If the driver is comfortable with the outer ones and they prove to be an improvement aerowise the will probably lose the other set. If the driver doesn't like the outer ones they probably won't use then.
ps - McLaren have had problems with mirrors breaking off at high speed over the last few seasons...
mini696
zulus wrote:Pitpass.com says Kimi is testing new aero package
Notable difference is rear wing development
Also bargeboard connection to the tub is shorter.
tetopelis
tetopelis
so is that mclaren mirror thing a fake..it seems real to me??
but it would be wild funny if they when to melbourne and had both of it on.hahaha..ppl would like "what in all the blue blazes were they thinkin?"..maybe the want every chance in the world to blind side the driver behind them with the glare coming of the mirror. and since they have a problem with those mirrors breaking of so often, its 4 times a chance for the mirror to hit the helmet of the driver behind. ron would be like "kimi!! you betrayed me...for that i cast you a shunder with breaking off mclaren parts..hah..let that reliability bite you back"..hahahaha
this all coming from a mclaren fan..:p
" If you want to win, get a Finn" - Hakkinen
mini696
Its real, they are testing it for vision.
The others are still there because it is ingrained into the tub design. Its cheaper to leave them there rather than build a brand new 'tub skin' just for testing. If the new position isn't liked by the drivers I assume they will retain the current position.
DaveKillens
DaveKillens
34
A good example of one design leading the other teams by the nose. Ferrari has the outboard mirrors, so do Renault. Now, in an obvious quick change of design, McLaren are mounting the mirrors outboard and determing if they are worth the change.
ginsu
ginsu
If they are testing them for vision, then they already know that it has a substantial aerodynamic benefit, so now they only need to know if the drivers can see properly out of them.
I love to love Senna.
Keir
Saribro wrote:Image
My mistake, I take it back :)
DaveKillens
DaveKillens
34
Thank you Keir, interesting picture. After pondering the different mirror locations, one thing that finally came to me was the aerodynamic area the mirrors resided in. They either are closer to the driver, about the middle of the sidepod area, or located in line with the wheels, chimney, and wheel flip-ups. Now, considering how many vanes and fins and other devices are located on the chassis, this area has to be of critical importance, especially since it leads finally to the rear wing. The air is carefully directed and massaged all along the chassis, in an effort to give the rear wing optimum airflow to achieve efficiency. Moving the mirrors further outboard takes them out of this area, and into the messy place where the wheels are. To me, it seems logical that the penalty in efficient airflow is less along the wheel line, since it's already an aerodynamic disaster, and does not impact on the rear wing performance.
mini696
DaveKillens wrote:Thank you Keir, interesting picture. After pondering the different mirror locations, one thing that finally came to me was the aerodynamic area the mirrors resided in. They either are closer to the driver, about the middle of the sidepod area, or located in line with the wheels, chimney, and wheel flip-ups. Now, considering how many vanes and fins and other devices are located on the chassis, this area has to be of critical importance, especially since it leads finally to the rear wing. The air is carefully directed and massaged all along the chassis, in an effort to give the rear wing optimum airflow to achieve efficiency. Moving the mirrors further outboard takes them out of this area, and into the messy place where the wheels are. To me, it seems logical that the penalty in efficient airflow is less along the wheel line, since it's already an aerodynamic disaster, and does not impact on the rear wing performance.
I also assume because they are furthur out in a more open area the disturbed air has a better chance of 'realigning' (and does it quicker)than it would in the enclosed area inboard.
ginsu
ginsu
Yeah, I agree Dave the solution is exactly as you describe. After all, there is no way that the flow after the mirrors is laminar, there is no reduction in area at the rear of the mirrors so the flow must be very turbulent. Having these mirrors inline with the rear wing seems like a big 'no no' to me. I really wonder why it takes F1 teams so long to update their designs, after all Ferrari came out with these over a year ago and the aerodynamic benefit has seemed almost obvious since then.
Vasco
Can mclaren get away with simply repositioning the mirrors? Surely the bodywork that follows the mirrors (flip-ups etc...) has been designed to work optimally with the current configuration of the mirrors...
pyry
pyry
actually mclaren are so slow they have two sets of mirrors so they can move aside when being lapped
four rings to rule them all
manchild
manchild
Whoever got excited by pace of BMW should cool off. Honda says that BMW used wings which aren't legal according to 2007 reg. so they'll loose some of the pace as they fit legal wings once the championship starts.
Shuhei Nakamoto wrote:"I know BMW have been using a non-2007 wing (in testing) so they lose one or two tenths, but we will still be behind."
