Just wondering what your thoughts are about this incident between MS and de la Rosa in 2006
flynfrog wrote:...since Michel was ahead in the corner he did not gain position they have since rewored that I believe
I had that though as well, but... there was some contact between the cars and this can change the way we should qualify this.Rob W wrote:Hands down Michael should have been penalised for that incident.
Im not saying right or wrong this is what the stewards saidRob W wrote:Hands down Michael should have been penalised for that incident.flynfrog wrote:...since Michel was ahead in the corner he did not gain position they have since rewored that I believe
Re: this... I think the point is... you're not automatically "ahead at the corner" if your nose is 1cm in front but the other car is completely inside you and already turning. I mean, where are they supposed to go? With Hamilton's move, he technically got his nose ahead but couldn't negotiate the corner so it was false economy.
Driving around the track requires negotiating the track and the other cars which are on it. The perfect line can't always be dictated by whoever has their nose 1cm infront as track position also matters. In the De La Rosa case it was Schumy who prevented a legit pass by driving off the track... i.e. gaining an unfair advantage by running straight. Same logic.
R
modbaraban wrote:I had that though as well, but... there was some contact between the cars and this can change the way we should qualify this.
Either [i]"MS cutting the corner to maintain position..
Users browsing this forum: Baidu [Spider], CCBot [Bot], Majestic-12 [Bot], timbo and 8 guests
