machin wrote:It seems unfair that the smaller drivers get an advantage out of this (as they always have done), -wouldn't it be fairer if there was a minimum driver weight... if any driver is under that weight then ballast must be added to a designated area (say behind the seat, middle of the back sort of height)... this would make things a bit fairer.... (having said that I'm not advocating that F1 drivers should be overweight... of course they should be fit, but then being fit would still benefit the driver even if there were a minimum weight).
xpensive wrote:As far as I understand, the car's minimum weight is already measured with the driver included, however, a lghter driver allows for ballast to be placed very low.
But, I don't think there's any rule yet against a bottom-heavy and air-headed driver?
Shaddock wrote:Lighter drivers will have more ballast to play with allowing finer tuning of the chassis setup. This was one of the reasons why Kubica outdrove Heidfeld last year.
Roland Ehnström wrote:Shaddock wrote:Lighter drivers will have more ballast to play with allowing finer tuning of the chassis setup. This was one of the reasons why Kubica outdrove Heidfeld last year.
Huh? Heidfeld is one of the smallest drivers on the grid, while I believe Kubica is one of the tallest. Nick is 167 cm and 61 kg according to his personal website, and I am pretty sure Robert is a fair bit longer as well as heavier.
Edit: According to http://formula1.about.com/od/profiles/p/kubica.htm Kubica is 6' and 160 lbs, which equals 183 cm and 72.5 kg.
wesley123 wrote:That realy aint healthy, im 190 cm 16 years old and i weight 65 kilos, heidfeld and kubica really arent healthy, im almost heavier then kubica and im really underweight.
roost89 wrote:
Weight isn't directly comparable to fitness. Take a Rugby player for example, they can weigh upwards of 14 stone (89kg) and they're very very fat people.
Users browsing this forum: Nebhotep, Yandex [Bot], yusy and 13 guests
