what's the different between low cone nose & hight cone nose
Post Sat Apr 25, 2009 1:44 am
indy car use a very low cone
but F1 use a very high cone
what's the different effect these two design have? what advantage & disadvantage they have?
Scania
Post Sat Apr 25, 2009 2:00 am
Formula 1 cars used to look more like the IRL cars with low pointed noses and low wings. This makes the air go up and over car, which is good for an oval, and pretty good for a race course, which is what the IRL cars need.
If changing direction is more important to you, like in an modern F1 car, then a higher nose is consider by some to interfere less with the wing, allowing the wing to use more air, and turn more quickly.
Giblet
Post Sat Apr 25, 2009 3:03 am
Giblet wrote:Formula 1 cars used to look more like the IRL cars with low pointed noses and low wings. This makes the air go up and over car, which is good for an oval, and pretty good for a race course, which is what the IRL cars need.
is that means:
Low nose>low Drag>low down focus
high nose>high Drag>high down focus
right?
Scania
Post Sat Apr 25, 2009 7:50 am
No not really, they both have their advantages and disadvantages.
Low nose:
-they generate much downforce
-wishbones can be place dlower on the chassis
-less clean airflow to the splitter/underbody
High nose:
-Clean underbody flow with lots of air going to the splitter
-The front wing is less interupted
-The nose generates less downforce
Post Sat Apr 25, 2009 11:07 am
And don't forgot the increased flow to the diffuser.
Meaning that while you may loose a bit of downforce from the nose itself, you get more downforce from the entire floor.
TheChad
Post Sat Apr 25, 2009 1:01 pm
The differences are driven by the regulations. If the rules were the same for all series, then we would see similar cars.
All engineers want to design the aero to deliver maximum downforce at minumum drag, while preserving such characteristics as aero balance, stability, and so on.
But different rules allow or disallow such things as ground effects, diffusers, wing size and location, wheelbase, track, the list goes on and on. So each problem requires a different solution. For instance, if a series allows for ground efffects, then the size and location of the front wing becomes less relevant. That's what happened back when ground effects (and active suspension)were allowed in F1. The underbody generated almost all the downforce, and the front wings were just there to balance the aero.
A proud Canadian, and yes, HOCKEY is our game.
DaveKillens
40
Post Sat Apr 25, 2009 3:18 pm
Yes good post Dave.
The rules are completely driven by where the cr is needed for, indycars have realy compact noses(the chassis is out of the irl time) to reduce drag for ovals, they nearly have no diffuser and for road courses they generate almost all their downforce ut of the wings.
The ground effect cars didnt have front wings anymore as it wasnt needed, the cars had very long sidepods to generate more downforce, and the only reason rear wings were on them was because of the diffuser interaction, the diffusers extended very high to generate huge downforce levels.
Also see the lmp's fr example, they all have raised footboxes to get a larger front diffuser, this small area can have enormous effect on the overall handling of the car, but this is pretty much irrelevant on the formula cars as these cars dont have understeering rpoblems.
The original idea of the raised nose was done by Tyrell to have the nose less influenced in the underbody airflow, the donwforce lsot by the higher nose was gained back double in the diffuser section, later on this idea got further developped with the front wing going under the nose to generate more front downforce, this was also develloped more and more with bigger planes under the nose until that was banned, now all the central downforce gneration is back tot the nose so they have different builds to meet their needs.
Most teams went for a semi height nose cone, and alot were really fat to get more downforce out of it i nthe excense of drag.
Return to General chat
Who is online
Users browsing this forum: Baidu [Spider], Exabot [Bot] and 7 guests
