rubbergoat wrote:Seems a bit harsh but I see your point - the discussion of comparing between teams has been brought up before on other forums...
I have listed all the drivers individually so you can always compare those
One question - how do you propose to take the differences between cars into account? I can see that you could do it with Fisi this year, but even then you have to factor in circuit types. Any ideas?
//Gavin Brown (RubberGoat)
http://f1numbers.wordpress.com/
No harshness intended
Outright speed is probably the easiest driver quality that the difference between the car can be taken into account.
Take each driver's fastest lap of the weekend(usually Q2, but sometmes not) add them up over the season and divide by the total of his teams' fastest lap.(if 1 drivers sets them all(like Alonso in '09 then his percentage will be 100).
So lets say the total for RBR this year was 1000 seconds and BGP was 990, normalize the times, and compare between the drivers.
of course this makes several assumptions that dont allways hold up... such as the faster driver extracted 100% from the car(we now that this is not true), and that a car's performance is not track sensitive, also not true... this effects the analysis because the track times are not equal. But those are the obstacles of any comparisons of this type.
