if it were inconel ,it should be quite heavy considering Inconel density(8,19g/cm³) is close to 321 stainless steel(8,03) ,whereas Titanium density(4,51) is more like Aluminium(2,7g/cm³) ...daytona1 wrote:Hi, Newbie, just joined so apologies if this is the wrong section for the following. I've found a lot of info on the material the F1 brake disc itself is made from, however, i'm interested in knowing what material the floating brake bell is made from? I have one here and it appears to be Titanium but it did cross my mind that it might be Inconel, possibly due to heat dissapating properties? Anyone with any solid info on this?
