Aero setup on oval track
Post Thu Jun 03, 2010 11:46 pm
on the oval track, should I amke more down force on inner side or outter side?
Scania
Post Fri Jun 04, 2010 12:53 am
Don't know that there's much ability to tune that in IRL or NASCAR. I'd say inside.. typically higher grip compounds.
Grip is a four letter word.
2 is the new #1.
Jersey Tom
126
Post Fri Jun 04, 2010 4:56 am
You want weight and downforce on the inside. Look at Nascar front fenders(Nationwide cars) the left front fender has much more surface area than rght front to produce more downforce.
Pierce89
16
Post Fri Jun 04, 2010 12:01 pm
but why indy car's rear wing were set to out sider higher then inner side?
Inner |/| outter
Scania
Post Fri Jun 04, 2010 12:55 pm
What kind of car? What kind of oval?
You can run different wing angles, profiles, gurneys, etc on the front wing of an open wheeler. Otherwise I'd love to know what you would try on the floor or rear wing. I would think it would be hard to induce any significant roll moment into the body with aero.
For a stock car body, the LF fender is built way bigger and it seems that surface area would produce more downforce but it's done for different reasons altogether. When you don't have to turn to the right you don't have to balance your yaw behavior. Aero roll moment is low in this case too.
stolenmojo
Post Tue Aug 03, 2010 4:39 pm
Scania wrote:on the oval track, should I amke more down force on inner side or outter side?
In "open air" it really doesn't matter, as the DF the car sees is through the mounting points to the chassis (usually through the nose) of the wing. It is the same force whether it's coming from the left or the right, with a slight difference in a dual mount (F1 style) due to the "leverage" of the two mounting points.
However following a car is the main reason you alter the wings in the front. Typically the inside wing is of a higher angle so that the driver can select a line inside of the car ahead and put air on at least one of his wings.
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
speedsense
Post Tue Aug 03, 2010 4:46 pm
I don't think you want to saturate your outside tire neither. The load transfer is already working for you, you want to bring the inside tire to work by giving it more downforce.
You'd typically build a oval car chassis to be offset to the inside too.
RacingManiac
Return to Automotive news and technology
Who is online
Users browsing this forum: No registered users and 3 guests
