HRT F112 Cosworth
Will HRT be in Q2 in 2012?
Yes - at the start of the Season
16
5%
Yes - by Germany
22
7%
No - not in 2012
167
54%
Never!
103
33%
Total votes: 308
Coefficient
Coefficient
Re: HRT F112 Cosworth
C_Stonehouse wrote:Marussia are running KERS next year; Are we expecting HRT to implement the system in the Singapore update?
No.
Petroltorque
Petroltorque
HRT have got enough problems managing the cooling on this year's car. In fact I would not be surprised if they thought they could get away without implementing KERS next year.
cbbcisace
cbbcisace
techF1LES
176
Photo courtesy of: Sutton Images
■ Copyright © Sutton Images 2012. All rights reserved.
■ Hosted at The Official F1™ Website
Jackles-UK
Wow!! I know HRT are on a tight budget but maybe they should have stretched to that 4 feet of heat-shielding!
techF1LES
176
Photo courtesy of: DR
■ Copyright © DR 2012. All rights reserved.
■ Hosted at Nextgen-Auto.com
Isn't the lower side impact protection beam positioned little bit "extraordinary low"?
Jackles-UK wrote:Wow!! I know HRT are on a tight budget but maybe they should have stretched to that 4 feet of heat-shielding!
Engines turned up for Monza perhaps?
Lurk
techF1LES wrote:Isn't the lower side impact protection beam positioned little bit "extraordinary low"?
The lower side-crashbox? AFAIK, all teams have them hidden in their floor so it is "ordinary low".
pyrosik is expensive ...as curing parts in autoclaves...that looks pretty much like the wrong matrix for that area...unfortunatelly no more metalwork on current cars ...so the fabricator to form the bodywork is also non existant at HRT...maybe some access to sls -one can do complete difussers in this technology....so ...yes i know Mclaren are the ones having big enough rp machines to do such a big part ..not in the range for HRT..I doubt this is available as a service commercially ....maybe in Italy...
Petroltorque
Petroltorque
Zircotek are a company that provides heat resistant coatings. The cooked area just looks like ill fitting carbon fibre.
The problem for HRT is the quality of their platform. They can't afford expensive technology but I'd expect a design without flaws in packaging leading to overheating and effective suspension layout allowing enough adjustment to keep tyres in the temperature window. After all the car design is down to the quality of the designer and his ideas.
MGP failed to produce parts suitable to exhaust blowingh in their first year as well...I´d say it´s inexperience and lack of funds driving this ....of course you can always do better.
It is not that hard to produce a piece of bodywork from sheetmetal in the heat affected area...I doubt the few grammes added -even if it were 500g would affect performance of the car at all but it would give a bit of crtedibility and peace of mind as the car won´t cook up on the grid.. :roll:
Petroltorque wrote:Zircotek are a company that provides heat resistant coatings. The cooked area just looks like ill fitting carbon fibre.
The problem for HRT is the quality of their platform. They can't aford expensive technology but I'd expect a design without flaws in packaging leading to overheating and effective suspension layout allowing enough adjustment to keep tyres in the temperature window. After all the car design is down to the quality of the designer and his ideas.
Zircotech is not that expensive, especially on a simple panel.
JMN
JMN
Not sure what hurts my eyes the most; the cooked carbon panel or the finish of that welding job. Frankly, I've seen bicycle frames with better finish than that.
Coefficient
Coefficient
Bad isn't it! Also, those awful mushroom head screws, can't they even afford a counter sink bit for their Makita?
That is good welding.. what is wrong with it?
